跳转到主内容
将插件升级到 4.2 后、 SnapCenter Oracle 备份仍在运行
42
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用于
  • 适用于 Oracle ( SCO ) 4.2 、 4.2.1 的 SnapCenter 插件
问题
升级到 4.2 或 4.2.1 后、备份将保持运行状态
检查日志后、 SMCore 会在几小时后超时(取决于RESTTimeout中的设置SMCoreServiceHost.exe.config):
WebException Encountered, Response null
Exception in method: InvokeXML.
System.Net.WebException: The operation has timed out
   at System.Net.WebClient.UploadDataInternal(Uri address, String method, Byte[] data, WebRequest& request)
Linuxspl_<JobID>.log 主机中的相应/var/opt/snapcenter/spl/logs调试行以以下三个调试行结尾:
c.n.o.c.p.OracleShellExecutor - Determining if TNS_ADMIN environment variable is set for oracle user
c.n.c.e.AbstractShellExecutor - EXE-00000: Executing shell command:
       0:/bin/sh -c "su""-""oracle""-c""env"
       1:su - oracle -c env
c.n.c.u.ConfigProperty - UTIL-00100: Application property shellResult.timeout is not defined
New to NetApp?
