由于缺少一个或多个最低要求、插件安装失败
适用场景
- 适用于Microsoft SQL Server的SnapCenter插件(SCSQL)
- 适用于Microsoft Windows Server的SnapCenter插件(SCW)
问题描述
- 由于主机上缺少一个或多个最低要求、插件安装失败
- 插件主机上
C:\Windows\SnapCenter plugin
的升级日志中出现错误:
Product: SnapCenter Plug-in for Microsoft SQL Server -- Error 1920. Service Plug-in for SQL Server Service (SCSQLPluginService) failed to start. Verify that you have sufficient privileges to start system services.
(ISP Action): SILENT INSTALL : ERROR : Unable to complete the installation.
(ISP Action): SILENT INSTALL : ERROR : Check for error in the logs and retry the installation.
(ISP Action): SILENT INSTALL : ERROR : Aborting the setup.
Action 'CA_Abort_Install' returned status 0x80070643
Original exit status: 0x80070643, final exit status: 0x00000643
