跳转到主内容
使用SAP HANA安装或升级适用于Unix的SnapCenter 插件无法运行安装程序
29
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx<a>升级</a><a>SCHANA</a><a>安装</a><a>以进行转换</a>
Last Updated:
适用场景
  • 适用于 SAP HANA 的 SnapCenter 插件( SCHANA )
问题描述
安装程序无法正常启动、尽管显示以下消息、但未创建日志目录、日志也未创建:
Installation of the package "snapcenter_linux_host_plugin.bin" failed on the host "<HOSTNAME.DOMAIN>" with ErrorCode:208, error: Verifying JVM.. Installation logs have been placed under the directory "/var/opt/snapcenter/logs/" on the host.
手动尝试安装时、例如
  1. 使用WinSCP将Linux安装文件移动到Linux主机、
  2. 设置 export LAX_DEBUG=true
  3. 使用相同的参数运行安装文件、而不使用静默选项、
在临时提取的安装目录中、可以发现以下错误:
[root@HOSTNAME] /tmp/install.dir.70165 # cat temp.lax
lax.user.dir=/tmp/install.dir.70165
lax.resource.dir=Linux
lax.class.path=/tmp/install.dir.70165/InstallerData:/tmp/install.dir.70165/InstallerData/installer.zip
lax.main.class=com.zerog.ia.installer.Main
lax.main.method=main
lax.nl.message.vm.not.loaded=The installer either could not find a Java VM, or the Java VM on this system is too old. The installer requires Java 1.1.5 or later. It can be downloaded from http://java.sun.com/products/jdk/1.1/jre/
New to NetApp?
