由于出现MySQL"线程正在中止"错误、SnapCenter克隆删除操作失败
适用场景
- SnapCenter服务器[SC]
- 适用于SQL的SnapCenter插件[SCSQL]
- Microsoft Internet信息服务器[IIS]
问题描述
- 由于MySQL
“Thread was being aborted”错误,SnapCenter克隆删除操作失败。 - 这种情况发生在
‘Deleting clone’触发子作业之前、进而导致备份删除操作失败、因为SnapCenter存储库中的备份已标记为后备克隆卷
Windows application logs report the following4/6/2024,1:8:28,878,Warning,hostname.xx.int,ASP.NET 4.0.30319.0,1309,"Event code: 3005 Event message: An unhandled exception has occurred. Event time: 4/6/2024 1:08:28 AM Event time (UTC): 4/6/2024 5:08:28 AM Event ID: e3499a2dc7cd43c18966734455da9704 Event sequence: 8 Event occurrence: 1 Event detail code: 0 Application information: Application domain: /LM/W3SVC/2/ROOT-1-133568537033053650 Trust level: Full Application Virtual Path: / Application Path: C:\Program Files\NetApp\SnapCenter WebApp\ Machine name: hostname Process information: Process ID: 4884 Process name: w3wp.exe Account name: IIS APPPOOL\SnapCenter Exception information: Exception type: HttpException Exception message: The remote host closed the connection. The error code is 0x80070057. at System.Web.Hosting.IIS7WorkerRequest.RaiseCommunicationError(Int32 result, Boolean throwOnDisconnect) at System.Web.Hosting.IIS7WorkerRequest.ExplicitFlush() at System.Web.WebSocketPipeline.DoFlush()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Web.WebSocketPipeline.<ProcessRequestImplAsync>d__9.MoveNext()Request information: Request URL: Request path: User host address: User: Is authenticated: False Authentication Type: Thread account name: IIS APPPOOL\SnapCenter Thread information: Thread ID: 11 Thread account name: IIS APPPOOL\SnapCenter Is impersonating: False Stack trace: at System.Web.Hosting.IIS7WorkerRequest.RaiseCommunicationError(Int32 result, Boolean throwOnDisconnect) at System.Web.Hosting.IIS7WorkerRequest.ExplicitFlush() at System.Web.WebSocketPipeline.DoFlush()--- End of stack trace from previous location where exception was thrown --- at System.Runtime.ExceptionServices.ExceptionDispatchInfo.Throw() at System.Web.WebSocketPipeline.<ProcessRequestImplAsync>d__9.MoveNext()
