跳转到主内容
克隆生命周期作业失败、并显示"Failed to mount storage resource、error is failed to create the volume Clone (无法挂载存储资源、无法创建卷克隆)"。
115
Visibility:
Votes:
0
Category:
snapcenter
Specialty:
snapx
Last Updated:
适用场景
  • SnapCenter服务器(SC)
  • 适用于SQL的SnapCenter插件(SCSQL)
  • Data ONTAP  9.14.1及先前版本。
问题描述
  • 在SnapCenter中、SCSQL克尔随机失败、并显示错误:
Failed to clone resources, error isMount operation failed with error Failed to mount storage resource, error is Failed to create the volume clone.'
  • SMCore日志:
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] ex.Message : The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Internal Error. Failed to lookup Snapshot copy tags for "<Snapshot_Name>". Error: Bad Snapshot name.
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] No retry condition match found or max retry reached. Throwing error The running command stopped because the preference variable "ErrorActionPreference" or common parameter is set to Stop: Internal Error. Failed to lookup Snapshot copy tags for "<Snapshot_Name>". Error: Bad Snapshot name.
2024-03-29T04:30:51.8943418-05:00 DEBUG SMCore_103293 PID=[3676] TID=[36] --PSHelper::RunCommand
2024-03-29T04:30:51.8943418-05:00 ERROR SMCore_103293 PID=[3676] TID=[36] Failed to create volume clone
New to NetApp?
