跳转到主内容
主机启动程序未使用某些路径登录到NetApp集群
146
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
san
Last Updated:
适用场景
  • ONTAP 9
  • FCP
  • SAN
  • VMware ESXi
问题描述
  • 主机启动程序已分区、但未登录到NetApp、从而导致主机端的路径不匹配
  • NetApp 端的 LIF 和物理端口已启动并处于在线状态,可以使用fcp adapter shownet int show命令进行验证,
  • 存储端的 SFP tx 和 rx 功率处于最佳范围
  • 某些ESXi主机启动程序未登录到所有目标LIF。 fcp initiator.xml log  显示未使用集群中所有节点的LIF登录的主机
  • 其他未受影响的主机使用相同的NetApp登录到相同的LUN端口
  •  每次重新启动主机时、我们都会看到某些或其他路径缺失。这表明重新启动后、主机无法启动会话以返回到存储
  • vserver fcp ping-igroup show显示了某些路径的zone-info-not available:
fcp ping-igroup show -vserver abc -igroup xyz -check-fabric true
AFF250::> vserver fcp ping-igroup show
      Igroup            Logical   Node    Ping    Extended
Vserver   Name     WWPN       Interface  Name    Status   Status
AFFVS01
      ESX01 10:00:00:10:9b:xx:xx:dc AFFA250-01_fc_lif_1 AFFA250-01 reachable wwpn-logged-in
      ESX01 10:00:00:10:9b:xx:xx:dc AFFA250-01_fc_lif_2 AFFA250-01 reachable wwpn-logged-in
      ESX01 10:00:00:10:9b:xx:xx:dc AFFA250-01_fc_lif_3 AFFA250-01 not-zoned -
      ESX01 10:00:00:10:9b:xx:xx:dc AFFA250-01_fc_lif_4 AFFA250-01 not-zoned -
      ESX01 10:00:00:10:9b:xx:xx:dc AFFA250-02_fc_lif_1 AFFA250-02 zone-info-not-available -
      ESX01 10:00:00:10:9b:xx:xx:dc AFFA250-02_fc_lif_2 AFFA250-02 reachable wwpn-logged-in
  • 在交换机端,主机和存储端口都将在nsshow 日志输出下以FC4类型登录:
N   685546;    3;10:00:00:10:9b:cc:xy:xx;20:00:00:10:9b:cc:yy:xx; 0x00000003
   SCR: Fabric-Detected Nx-Port-Detected
   FC4s: FCP FC-NVMe
   PortSymb: [34] "Emulex PPN-10:00:00:10:9b:cc:ab:xx"
   NodeSymb: [94] "Emulex LPm32002-D FV14.0.539.26 DV14.0.622.0 HN:abcc.hbcxxm.com OS:VMware ESXi 7.0.3"
   Fabric Port Name: 20:55:88:94:71:a2:88:xx
   Permanent Port Name: 20:11:d8:1f:cc:69:75:xx
   Device type: NPIV Initiator
   Port Index: 85
   Redirect: No
   Partial: No
   LSAN: No
   Slow Drain Device: No
   Device link speed: 32G
   Connected through AG: Yes
   Real device behind AG: Yes
   FCoE: No
   Connected through FC-LAG: No
   FC4 Features [FCP]: Initiator
   FC4 Features [FC-NVMe]: Initiator
N   68fb41;    3;20:07:00:a0:98:f3:yy:xy;20:08:00:a0:98:f3:xx:xx; 0x00000003
   FC4s: FCP Application-Services
   PortSymb: [63] "NetApp FC Target Port (LPe16000) VVMxxx_DATA_SVM:lif"
   NodeSymb: [34] "NetApp Vserver SVM"
   Fabric Port Name: 20:fb:88:94:71:a2:88:ab
   Permanent Port Name: 50:0a:09:81:80:61:fa:aa
   Device type: NPIV Target
   Port Index: 251
   Redirect: No
   Partial: No
   LSAN: No
   Device link speed: 16G
   Connected through AG: No
   Real device behind AG: No
   FCoE: No
   FC4 Features [FCP]: Target
  • 确保 ONTAP CLI 上下文正确,以防止误报输出fcp ping 启动器
  • 要 进一步隔离问题描述、需要执行以下步骤:
  • 重新扫描存储适配器(# esxcli storage core adapter rescan -A vmhbaX )
  • 切换连接到主机启动程序的交换机端口并进行验证、可以在Brocade交换机上使用portdisable 命令、在Cisco交换机上使用shutdown 命令。
  • 重置VMware上的主机HBA  (# esxcli storage san fc reset -A vmhbaX )
  •  使用以下命令重置NetApp端的LUN:
注意:如果存储lifs已与任何其他主机进行分区,请确保这些主机已配置适当的冗余路径和多路径。
::> net int modify -vserver <vserver_name> -lif <lif_name> -status-admin down
::> net int modify -vserver <vserver_name> -lif <lif_name> -status-admin up
New to NetApp?
