跳转到主内容
系统反复重新启动、并显示邮箱磁盘错误
145
Visibility:
Votes:
0
Category:
aff-series<a>2009080475-for-translation</a><a />
Specialty:
HW
Last Updated:
适用场景
  • AFF-A400
  • ONTAP 9.9.1.1 P2
问题描述
  • 系统在 Waiting for givebackReservation conflict 重新启动后启动、但出现错误。
Reservation conflict found on this node's disks!
 Local System ID: 123456789
 Press Ctrl-C for Maintenance menu to release disks.
 [node2:cf.fmns.skipped.disk:notice]: While releasing the reservations in "Waiting For Giveback" state Failover Monitor Node State(fmns) module skipped the disk 0a.00.8 that is owned by 123456789 and reserved by 987654321.
 [node2:cf.disk.ResvFail:ALERT]: Disk 0d.00.9P3 has been reserved by the High Availability (HA) partner as part of a takeover operation.
 [node2:cf.disk.ResvTakeOver:notice]: This node will wait for giveback and the disk reservations to be released.
 Disk reservations have been released
 Waiting for giveback...(Press Ctrl-C to abort wait)
  • Waiting for giveback 状态重新启动节点后、系统不会启动、并反复重新启动、但 All Local mailbox disks are inaccessible 出现错误。
 Rebooting ...
 Uptime: 6m48s
 BIOS Version: 16.4
 PEI start.
 CPU PEI initialization.
 Wait BMC self-test result.
 BMC self-test: OK.
 UPI initialization.
 CPU initialization.
 Running quick memory initialization.
 SPI FLASH: Primary BIOS
 PEI end.
 DXE start.
 USB initialization.
 PCI host bridge initialization.
 CSM initialization.
 PCI Bus initialization start.
 BDS start.
 Console output devices connect.
 Ready to boot.
 Boot Loader version 6.4.9
 Copyright (C) 2000-2003 Broadcom Corporation.
 Portions Copyright (C) 2002-2021 NetApp, Inc. All Rights Reserved.
 ACPI RSDP Found at 0x6cc29000
 Starting AUTOBOOT press Ctrl-C to abort...
 Loading X86_64/freebsd/image2/kernel:0x200000/1147616 0x319000/10792232 0xf64000/3948368 0x1327f50/4387448 0x200240/1016 Entry at 0xffffffff80319000
 Loading X86_64/freebsd/image2/platform.ko:0x1758000/4068960 0x1b39660/628568
 Starting program at 0xffffffff80319000
 ---<<BOOT>>---
 NetApp Data ONTAP 9.9.1P2
 IPMI device unit 0 rev. 1, firmware rev. 13.04, version 2.0, device support mask 0xbf
 IPMI device unit 1 rev. 1, firmware rev. 13.04, version 2.0, device support mask 0xbf
 Copyright (C) 1992-2021 NetApp.
 All rights reserved.
 * Press Ctrl-C for Boot Menu. *
 [node2:fmmb.disk.notAccsble:notice]: All Local mailbox disks are inaccessible.
 [node2:cf.fsm.takeoverOfPartnerDisabled:error]: Failover monitor: takeover of node1 disabled (HA interconnect error. Verify that the partner node is running and that the HA interconnect cabling is correct, if applicable. For further assistance, contact technical support).
 [node2:kern.syslog.msg:notice]: domain xing mode: off, domain xing interrupt: false
 [node2:cf.fsm.takeoverOfPartnerDisabled:error]: Failover monitor: takeover of node1 disabled (unsynchronized log).
  • 在受损节点重新启动期间、配对节点上的HA互连端口已启动。
SYSCONFIG-A
   slot 0: 10G/25G Ethernet Controller CX5
      e0a MAC Address:    xx:xx:xx:xx:xx:xx (auto-25g_cr-fd-up)
          SFP Vendor:         Amphenol
          SFP Part Number:    NDCCGF-N103
          SFP Serial Number:  APF1234567
      e0b MAC Address:    xx:xx:xx:xx:xx:xx (auto-25g_cr-fd-up)
          SFP Serial Number:  APF7654321
New to NetApp?
