跳转到主内容
系统运行状况警报报告服务处理器配置不正确
213
Visibility:
Votes:
0
Category:
fas-systems<a>FAS</a><a>1091152</a>
Specialty:
HW
Last Updated:
适用场景
  • ONTAP 9
  • FAS/AFA 型号
问题描述
  • system health alert show 有关不当行为的报告:
Cluster::> system health alert show
        Node: Cluster-01
      Resource: SP Config
      Severity: Major
   Indication Time: Fri Apr 17 09:17:32 2020
      Suppress: false
     Acknowledge: false
   Probable Cause: Service Processor is not properly configured.
   Possible Effect: You might not be able to use the Service Processor to
           remotely access, monitor, and troubleshoot your
           storage system.
 Corrective Actions: 1. Use the "system service-processor network modify" command to configure the network interface of the Service Processor.
           2. Use the "system service-processor image modify -node Cluster-01 -autoupdate true" to configure AutoUpdate feature of the Service Processor.
           3. Contact the technical support if the alert persists.
  • system health subsystem show 显示  服务处理器 子系统的降级状态
Cluster::> system health subsystem show
Subsystem      Health
SAS-connect     ok
Environment     ok
Memory       ok
Service-Processor degraded
Switch-Health    ok
CIFS-NDO      ok
Motherboard     ok
IO         ok
MetroCluster    ok
MetroCluster_Node ok
FHM-Switch     ok
FHM-Bridge     ok
SAS-connect_Cluster ok
13 entries were displayed.
  • system controller show 显示 处于降级状态的节点
Cluster::> system controller show
Controller Name       System ID    Serial Number    Model   Status
Cluster-01           537xxxxxx    621xxxxxxxxx    FAS2650  degraded
Cluster-02           537xxxxxx    621xxxxxxxxx    FAS2650  ok
New to NetApp?
