A800 互连断开,e0a/e0b 致命奇偶校验错误 (0x10)
适用于
- AFF A800,AFF C800,ASA A800,ASA C800
- 双 40/100G 以太网 T62100-MEZZ
- ONTAP 9
问题
- 节点通电、重新启动或升级后 ,系统处于部分回馈状态,互连状态为:"
RDMA Interconnect is down" - 存储故障转移状态为:"
Storage failover interconnect error. NVRAM log not synchronized. Disk inventory not exchanged" - 控制台日志显示:
e0a/e0b:Fatal parity error (0x10) - ONTAP OS 和 BMC、BIOS 和 T62100 固件均已更新并在两个节点上运行
- EMS 日志:
May 02 07:58:09 [node_name:netif.fatal.err:ALERT]: The network device in slot 0 encountered fatal error e0a/e0b.
May 02 22:49:05 [node_name: kernel: netif.linkDown:info]: Ethernet e0a: Link down, check cable.
May 02 22:49:05 [node_name: kernel: netif.linkDown:info]: Ethernet e0b: Link down, check cable.
May 02 22:49:05 [node_name: intr: rlib.ifconfig.linkEvent:notice]: params: {'ifname': 'e0b', 'eventType': 'DOWN'}
May 02 22:49:05 -0800 [node_name: vifmgr: vifmgr.portdown:notice]: A link down event was received on node node_name, port e0a.
May 02 22:49:05 -0800 [node_name: nvmm_error: nvmm.mirror.offlined:debug]: params: {'mirror': 'HA_PARTNER'}
May 02 22:49:05 -0800 [node_name: vifmgr: vifmgr.clus.linkdown:EMERGENCY]: The cluster port e0a on node node_name has gone down unexpectedly.
May 02 23:00:00 -0800 [node_name: statd: ic.HAInterconnectDown:error]: HA interconnect: Interconnect down for 10 minutes: link0 down
May 02 23:00:00 -0800 [node_name: statd: callhome.hainterconnect.down:alert]: Call home for HA INTERCONNECT DOWN due to link0 down.
