节点在引导时报告 NVRAM 电池电源故障
适用场景
- 光纤网络连接存储( FAS )系统
- 所有闪存 FAS ( AFF )系统
问题描述
节点在引导时报告以下警告信息:
WARNING: The battery is experiencing a critical failure:
- Battery power fault
Without a working battery, the system cannot retain data
during a power outage, which can result in data loss.
Power down the system and verify that the battery is
properly installed.
To ignore this failure and boot the system in a mode
where data loss might occur, press 'c' followed by 'Enter'
CAUTION: Using this appliance without NVRAM
battery backup coupled with a power
failure condition CAN CAUSE DATA LOSS.
Are you sure you want to continue (y or n)?
或
HA Group Notification (BATTERY (fault)) CRITICAL
