跳转到主内容
Coming soon...New Support-Specific categorization of Knowledge Articles in the NetApp Knowledge Base site to improve navigation, searchability and your self-service journey.
由于多磁盘故障、HA对已关闭
适用场景
AFF A250
问题描述
  • 由于 2 个磁盘发生故障,节点自动关闭,第三个磁盘正在重建,因此 " 重建已停止 " 。
Aggregate aggregate1 (failed, raid_dp, partial, fast zeroed) (block checksums)
  Plex /aggregate1/plex0 (offline, failed, inactive)
   RAID group /aggregate1/plex0/rg0 (partial, block checksums)
    RAID Disk   Device   HA  SHELF BAY CHAN Pool Type  RPM  Used (MB/blks)   Phys (MB/blks)
    dparity    0n.0P2   0n   0   0      0 SSD-NVM   N/A 867680/222126208  867688/222128256 (reconstruct stalled)
    parity     0n.1P2   0n   0   1      0 SSD-NVM   N/A 867680/222126208  867688/222128256 (fast zeroed)
    data   FAILED      N/A             867680/ -
    data      0n.3P2   0n   0   3      0 SSD-NVM   N/A 867680/222126208  867688/222128256
    data      0n.19P2   0n   0   19      0 SSD-NVM   N/A 867680/222126208  867688/222128256
    Raid group is missing 2 disks.
Mon Jul 05 2021 09:16:31 GMT [node_name1: statd: monitor.brokendisk.notice:NOTICE]: When two disks are broken in raid_dp volume, the system shuts down automatically every 24 hours to encourage you to replace the disk. If you reboot the system, it will run for another 24 hours before shutting down.
  • 多磁盘崩溃:
Panic_Message: aggr aggregate1: raid volfsm, fatal multi-disk error.. Raid type - raid_dp Group name plex0/rg0 state DEGRADEDRECONS. 1 disk failed in the gr...
  • WAFL 不一致错误:
Sat Jul 03 02:27:13 +0000 [node_name1: wafl_exempt00: wafl.raid.incons.userdata:error]: WAFL inconsistent: inconsistent user data block at VBN 729078144 (vvbn:69395562 fbn:69395562 level:0) in private inode (fileid:container snapid:0 file_type:6 disk_flags:0xc10000800800143 error:120 raid_set:1) in volume volume_name@vserver:ab0123c4-56de-78fg-9hi0-j123kl45m6n7.
Sat Jul 03 02:27:13 +0000 [node_name1: wafl_exempt00: wafl.incons.userdata.vol:alert]: WAFL inconsistent: volume volume_name@vserver:ab0123c4-56de-78fg-9hi0-j123kl45m6n7 has an inconsistent user data block. Note: Any new Snapshot copies might contain this inconsistency.
Sat Jul 03 02:27:13 +0000 [node_name1: wafl_exempt00: callhome.wafl.inconsistent.user.block:alert]: Call home for WAFL INCONSISTENT USER BLOCK
  • NVMe SSD 磁盘的 PCIe 链路错误:
Fri Jun 25 2021 11:30:52 GMT [node_name1: kernel: nvme.link.error:ERROR]: PCIe link initialization error for NVMe SSD in slot 22.
New to NetApp?
Scan to view the article on your device
