对集群网络使用MetroCluster兼容交换机时、MetroCluster IP中出现不受支持的交换机警报
适用场景
- MetroCluster IP后端兼容交换机。示例:
- N9K-C93240YC-FX2
- N9K-C9336C-FX2-E
问题描述
- 报告的运行状况监控器警报:
[Node-1: mgwd: callhome.hm.alert.major:alert]: Call home for Health Monitor process cshm:SwitchCommunityString_Alert[cluster-stor-sw2(XXXXXXXXXX)].
[Node-1: cshmd: hm.alert.raised:alert]: Alert Id =UnsupportedSwitch_Alert, Alerting Resource = cluster-stor-sw2(XXXXXXXXXX) raised by monitor ethernet-switch
system health alert show输出:
Node: Node-1
Monitor: ethernet-switch
Alert ID:SwitchCommunityString_Alert
Alerting Resource: cluster-stor-sw2(XXXXXXXXXX)
Subsystem: Switch-Health
Indication Time: Fri Nov 04 07:07:04 2022
Perceived Severity: Major
Probable Cause: Configuration_error
Description: Ethernet switch "cluster-stor-sw2(XXXXXXXXXX)" with IP address "10.X.XXX.XXX" is not reachable via SNMP. Incorrect SNMP community string might be configured on the Ethernet switch.
Corrective Actions: Check the SNMP community string on the Ethernet switch to verify that the expected community string is configured. Use the "system switch ethernet show -snmp-config" command to view the expected community string.
Possible Effect: Ethernet switch communication problems and accessibility issues.
Node: Node-1
Alert ID:UnsupportedSwitch_Alert
Description: Unsupported Ethernet switch is detected.
Corrective Actions: Unsupported Ethernet switch "cluster-stor-sw2(XXXXXXXXXX)" found. Connect a supported Ethernet switch to the network.
Possible Effect: Communication problems and network connectivity issues occur.
- 由于以下警报、交换机运行状况将降级:
Cluster::> system health subsystem show
Subsystem Health
SAS-connect ok
Environment ok
Memory ok
Service-Processor ok
Switch-Health degraded
CIFS-NDO ok
Motherboard ok
IO ok
MetroCluster ok
MetroCluster_Node ok
FHM-Switch ok
FHM-Bridge ok
SAS-connect_Cluster ok
