跳转到主内容
由于缆线故障、导致Brocade交换机端口盖板
570
Visibility:
Votes:
1
Category:
fabric-interconnect-and-management-switches
Specialty:
brocade
Last Updated:
适用场景
Brocade 交换机上的端口
问题描述
  • 交换机端口状态为online under switchshow
/fabos/bin/switchshow :
Index Slot Port Address Media  Speed     State   Proto
129   4   33   708100   id   N32    Online    FC  F-Port  10:00:00:10:9b:xx:xx:xx
  • porterrshow 下,  报告多个link failureloss sync 错误以及其他介质错误,如enc_out, crc err, crc g_eof, c3timeout Tx, pcsuncorr 错误。
/fabos/cliexec/porterrshow :
      frames     enc    crc    crc    too    too    bad    enc   disc   link   loss   loss   frjt   fbsy    c3timeout    pcs    uncor
     tx     rx    in    err    g_eof   shrt   long   eof    out   c3    fail   sync   sig            tx    rx    err    err
100:   14.1k   5.8k   2.2k  964    932     0     0    32    3.9g  6    12    0     4.4k   0     0     0     0     0     0
129:   20.6k   20.7k    0       0       0       0       0       0       0       9       2.5k   0       7.2k    0       0       9       0       1.1k   26.0k
/fabos/cliexec/porterrshow:
  37:   2.3g   6.4g   0     0     0     0     0     0     0    53     2     0     4     0     0    53    0     0     0
  • sfpshow 报告Rx值过低。
RX Power:    -15.1   dBm (30.7 uW)
TX Power:    -1.7    dBm (678.9 uW)
  • portshow 输出确认端口为Online 且处于In_Sync 状态、并且 Lr_In 大于Ols_out 、这表示问题描述是switchport外部端口。
portshow 37
portDisableReason: None
portState: 1    Online
Protocol: FC
portPhys:  6    In_Sync   portScn:   32    F_Port
FC Fastwrite: OFF
Interrupts:     48   Link_failure: 2   Frjt:      0
Unknown:       6   Loss_of_sync: 0   Fbsy:      0
Lli:         48   Loss_of_sig:  4
Proc_rqrd:      159  Protocol_err: 0
Timed_out:      0   Invalid_word: 0
Tx_unavail:     0   Invalid_crc:  0
Delim_err:      0   Address_err:  0
Lr_in:        6  Ols_in:     2
Lr_out:       2   Ols_out:    3
Cong_Prim_in:     0
  • Fabriclog 下,可以看到这两个端口在闪烁。
Fabriclog:
Switch 0; Tue Oct 11 12:34:12 2022 IST (GMT+5:30)
12:34:12.020011 SCN Port Offline;rsn=0x2,g=0x530            D2,P0  D2,P0  15    NA
12:34:12.020017 *Removing all nodes from port               D2,P0  D2,P0  15    NA
12:34:12.112102 SCN Port Offline;rsn=0x0,g=0x532            D2,P0  D2,P0  127   NA
12:34:12.112108 *Removing all nodes from port               D2,P0  D2,P0  127   NA
12:36:40.840204 SCN LR_PORT(0);g=0x530                      D2,P0  D2,P0  15    NA
12:36:40.860941 SCN Port Online; g=0x530,isolated=0         D2,P0  D2,P1  15    NA
12:36:40.861044 Port Elp engaged                            D2,P1  D2,P0  15    NA
12:36:40.861057 *Removing all nodes from port               D2,P0  D2,P0  15    NA
  • 根据sfpshow 输出、交换机端的SFP光学值处于最佳范围-
RX Power:   -1.7   dBm (681.90uW)
TX Power:   -1.5   dBm (701.10 uW)
  • 交换机记录了C4-5040 消息-
    2024/09/17-20:13:45:225851 (IST), [C4-5040], 2240091/0, SLOT 1 | CHASSIS | PORT 3/11, INFO,  SWITCH, Link loss of sync debouncing event detected: Slot 3/Port 11(122)
  • c4-5040 当由于同步丢失而重置端口链路时、会记录-。将启动反跳计时器以清除同步信号的丢失。如果即使在上述计时器到期后仍未清除、则会发布C4-5040防抖动日志。
  • fabriclog 中、我们会看到端口脱机、并且   交换机上出现LR_in
    Switch 0; Tue Sep 17 20:13:23 2024 IST (GMT+5:30)
    20:13:23.722607 SCN Port Offline;rsn=0x2,g=0x16a       D2,P0  D2,P0  11   NA
    20:13:23.722613 *Removing all nodes from port         D2,P0  D2,P0  11   NA
    20:13:24.365532 SCN LR_PORT(0);g=0x16a            D2,P0  D2,P0  11   NA
    20:13:24.423719 SCN Port Online; g=0x16a,isolated=0      D2,P0  D2,P1  11   NA
    20:13:24.423926 Port Elp engaged               D2,P1  D2,P0  11   NA
    20:13:24.423938 *Removing all nodes from port         D2,P0  D2,P0  11   NA
    20:13:24.424123 SCN Port F_PORT                D2,P1  D2,P0  11   NA
    20:13:24.538573 SCN LR_PORT(0);g=0x16a LR_IN         D2,P0  D2,P0  11   NA
  • portstatsshow下显示的错误计数器-
portstatsshow 11
er_bad_os         13
phy_stats_clear_ts    09-13-2024 IST Fri 03:01:23    Timestamp of phy_port stats clear
lgc_stats_clear_ts    09-13-2024 IST Fri 03:01:23    Timestamp of lgc_port stats clear
Lr_in       0       top_int : Number of link resets received
         1       bottom_int : Number of link resets received
Link_failure   0       top_int : Number of link failures
         1       bottom_int : Number of link failures
Loss_of_sig    0       top_int : Number of instances of signal loss detected
         1       bottom_int : Number of instances of signal loss detected
  • MAPS policy 中  ,我们可以通过 link fail ,loss sigLR 报告:
映射端口3/11的警报:
LOSS_SYNC(SyncLoss) -
LF(LFs)        3/11(1)
LOSS_SIGNAL(LOS)   3/11(1)
PE(Errors)
STATE_CHG       3/11(2)
LR(LRs)        3/11(1)
  • 在旧的supportsaves中查看sfpshow 端口时、  可以看到RX 电源 出现故障、但仍具有相当高的价值
Temperature: 51    Centigrade
Current:    7.786   mAmps
Voltage:    3329.70 mVolts
12-SEP 2025 20h25
Current:    7.788   mAmps
Voltage:    3318.80 mVolts
RX Power:   -1.6   dBm (685.00uW)
TX Power:   -1.5   dBm (703.20 uW)
12-SEP 00h05
Current:    7.796   mAmps
Voltage:    3312.40 mVolts
RX Power:   -1.6   dBm (694.90uW)
TX Power:   -1.5   dBm (703.00 uW)
  • errdump 日志下触发的规则defALL_32GSWL_SFPRXP_63defALL_OTHER_F_PORTSSTATE_CHG_5 以及loss signallink failuresframe timeout detected 错误。
2022/10/11-12:41:00, [MAPS-1004], 46328, SLOT 1 | FID 128, INFO, XXX, SFP 3/15, Condition=ALL_32GSWL_SFP(RXP<=63), Current Value:[RXP, 0 uW], RuleName=defALL_32GSWL_SFPRXP_63, Dashboard Category=Port Health.
2022/10/11-12:41:00, [MAPS-1004], 46329, SLOT 1 | FID 128, INFO, XXX, SFP 12/15, Condition=ALL_32GSWL_SFP(RXP<=63), Current Value:[RXP, 0 uW], RuleName=defALL_32GSWL_SFPRXP_63, Dashboard Category=Port Health.
2022/10/11-12:43:00, [MAPS-1004], 46330, SLOT 1 | FID 128, INFO, XXX, SFP 3/15, Condition=ALL_32GSWL_SFP(RXP<=63), Current Value:[RXP, 0 uW], RuleName=defALL_32GSWL_SFPRXP_63, Dashboard Category=Port Health.
2022/10/11-12:43:00, [MAPS-1004], 46331, SLOT 1 | FID 128, INFO, XXX, SFP 12/15, Condition=ALL_32GSWL_SFP(RXP<=63), Current Value:[RXP, 0 uW], RuleName=defALL_32GSWL_SFPRXP_63, Dashboard Category=Port Health.
2023/02/20-16:42:20 (IST), [MAPS-1003], 9812, SLOT 2 | FID 128 | PORT 4/33, WARNING, switch, slot4 port33, F-Port 4/33, Condition=ALL_HOST_PORTS(STATE_CHG/min>5), Current Value:[STATE_CHG, 6], RuleName=defALL_HOST_PORTSSTATE_CHG_5, Dashboard Category=Port Health, Quiet Time=None.
2023/02/20-16:42:20 (IST), [MAPS-1003], 9813, SLOT 2 | FID 128 | PORT 4/33, WARNING, switch, slot4 port33, F-Port 4/33, Condition=ALL_OTHER_F_PORTS(STATE_CHG/min>5), Current Value:[STATE_CHG, 6], RuleName=defALL_OTHER_F_PORTSSTATE_CHG_5, Dashboard Category=Port Health, Quiet Time=None.
2022/06/26-03:53:42, [MAPS-1003], 42403, SLOT 2 | FID 128, WARNING, switch, slot6 port9, U-Port 6/9, Condition=ALL_PORTS(LOSS_SIGNAL/min>3), Current Value:[LOSS_SIGNAL, 386 LOS], RuleName=defALL_PORTSLOSS_SIGNAL_3, Dashboard Category=Port Health.
2022/06/26-03:54:42, [MAPS-1003], 42404, SLOT 2 | FID 128, WARNING, switch, slot6 port9, U-Port 6/9, Condition=ALL_PORTS(LOSS_SIGNAL/min>3), Current Value:[LOSS_SIGNAL, 378 LOS], RuleName=defALL_PORTSLOSS_SIGNAL_3, Dashboard Health.
2021/10/23-23:38:47, [MAPS-1003], 55690, SLOT 1 | FID 128, WARNING, Fabric1, slot10 port31, U-Port 10/31, Condition=ALL_PORTS(LF/min>3), Current Value:[LF, 4], RuleName=defALL_PORTSLF_3, Dashboard Category=Port Health.
2021/10/23-04:24:46, [PORT-1003], 53615, SLOT 1 | FID 128, WARNING, Fabric1, Port 223 Faulted because of many Link Failures.
2020/04/08-21:35:56, [C3-1014], 2556, CHASSIS, WARNING, Brocade6510,  Link Reset on Port S0,P8(12) vc_no=0 crd(s)lost=12 auto trigger.
2020/04/09-09:03:42, [C3-1014], 2557, CHASSIS, WARNING, Brocade6510,  Link Reset on Port S0,P8(12) vc_no=0 crd(s)lost=12 auto trigger.
2023/10/15-01:03:18, [AN-1014], 589, FID 128, INFO, SWITCH, Frame timeout detected, tx port 37 rx port 15, sid 650900, did 632501, timestamp 2023-10-15 01:03:18 .
2023/10/15-01:03:18, [LOG-1000], 594, FID 128, INFO, SWITCH, Previous message repeated 5 time(s).
  • RuleName=defALL_32GSWL_SFPRXP_63Rx电源开始降级时触发、表示上游问题描述I、e  SFP或缆线出现故障
  • 在存储 端、EMS 日志会报告link break 事件:
     [?]  Tue Sep 17 20:13:44 +0530 [NetApp-2: fct_tpd_work_thread_0: scsitarget.slifct.linkBreak:error]: Link break detected on Fibre Channel target HBA 3d with event status 1 , topology type 1, status1 0x0, status2 0x0.
     [?]  Tue Sep 17 20:13:45 +0530 [NetApp-2: fct_tpd_work_thread_0: scsitarget.hwpfct.linkUp:notice]: Link up on Fibre Channel target adapter 3d.
  • 涵盖问题描述Time  ITW errorsloss of sync 的性能归档同时进行。
  • 在交换机端、我们也可以看到loss of sig 错误。
  • 这表示交换机和存储之间的链路上发生了一些loss of signal、因此、存储启动了链路重置以从这种情况中恢复。
  • 这反过来又会触发ITW errors 、因为在此期间重置链路时、到达该链路的帧将被丢弃。
  • ITW 错误指示电缆有故障。
  • 要进一步隔离问题描述,请重新拔插电缆。
  • 如果问题描述仍然存在、请重新拔插开机自检电缆、请继续执行解决方案。
New to NetApp?
