跳转到主内容
NS224 磁盘架上缺少单个磁盘
54
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • NS224磁盘架
问题描述
  • NS224磁盘架上的一个磁盘在两个路径上都丢失。
  • 如果驱动器在两个路径上都缺失、则在ONTAP中将看不到它、并且绿色磁盘LED不会亮起。
cluster1::> run -node <node name> sysconfig -a
00.1.16: NETAPP   X4013S17337T6NTE NA51 7325.4GB 4160B/sect (S60RNXXXXXXXXX)
00.1.17: NETAPP   X4013S17337T6NTE NA51 7325.4GB 4160B/sect (S60RNXXXXXXXXX)
<No Drive 18 listed here as expected>
00.1.19: NETAPP   X4013S17337T6NTE NA51 7325.4GB 4160B/sect (S60RNXXXXXXXXX)
00.1.20: NETAPP   X4013S17337T6NTE NA51 7325.4GB 4160B/sect (S60RNXXXXXXXXX)
cluster1::> storage disk show
e5b.00.3.16  B    e0c.00.0.16  A     0   16
e5b.00.3.17  B    e0c.00.0.17  A     0   17
e5b.00.3.19  B    e0c.00.0.19  A     0   19
e5b.00.3.20  B    e0c.00.0.20  A     0   20
  • 系统过渡 到混合路径HA。
cluster1::> system node run -node node1 sysconfig
     NetApp Release 9.8P10: Fri Feb  4 04:27:32 EST 2022
     System ID: XXXXXXXXXX (node1); partner ID: XXXXXXXXXX (node2)
     System Serial Number: XXXXXXXXXXXX (node1)
     System Rev: A0
     System Storage Configuration: Mixed-Path HA
New to NetApp?
