逻辑接口( LIF )处于管理状态,但运行状态为关闭(启动 / 关闭) ONTAP 节点重新启动后
适用于
- ONTAP 9
- FCoE
- 运行 NX-OS 大于的 Cisco Nexus 5000 系列( 5k )交换机 7.3 ( 3 )
- LACP 接口组与 FCoE 目标共存
问题
- 重新启动 ONTAP 节点后, FCoE 目标端口将以管理员方式启动并运行关闭。
cluster1::> network interface show -data-protocol fcp
Logical Status Network Current Current Is
Vserver Interface Admin/Oper Address/Mask Node Port Home
fcp-svm
fcp-lif-01-0e
up/down 20:01:00:a0:98:01:23:45
cluster1-01 0e true
fcp-lif-02-0e
up/down 20:02:00:a0:98:01:23:45
cluster1-02 0e true
- 这些逻辑接口( Logical Interface , LIF )表明,对交换机执行的 FDISCC 命令失败。
cluster1::> network interface show -data-protocol fcp -fields status-admin,status-oper,status-extended
vserver lif status-oper status-extended status-admin
fcp-svm fcp-lif-01-0e down FDISC error - ID could not be acquired for this virtual port.
fcp-svm fcp-lif-02-0e down FDISC error - ID could not be acquired for this virtual port.
- 在 ONTAP 中,您将看到
- 在
'event log show
启动后不久,诊断主页中的输出 " 。
- 在
Thu Jan 01 10:01:10 CDT [netaapp-n01: fct_tpd_work_thread_0: scsitarget.ispfct.configChanged:notice]: FCP target 0e reported a port configuration change. FDISC RJT - FDISC failed because a LS_RJT was received for virtual port 1.
- 在 Cisco 交换机中,查看
`show platform software fcoe_mgr event-history errors`
3700) Event:E_DEBUG, length:112, at 722146 usecs after Thu Jan 01 10:01:10 2020 [102] fcoe_mgr_handle_fka(4440): sending cvl to unknown vnport for 1002, 00:a0:98:bc:c7:XX mac:00:a0:98:bc:c7:XX
3701) Event:E_DEBUG, length:86, at 722010 usecs after Thu Jan 01 10:01:10 2020 [102] fcoe_mgr_handle_fka(4432): FKAs received from unknown VN port on interface vfc9
