错误的 HA 组通知电池电量已满,容量不足紧急消息
适用于
FAS2750
问题
- 收到的 AutoSupport 消息:
Notification (BATTERY (full charge capacity low)) EMERGENCY
Fri Feb 14 13:50:52 GMT [node_name: env_mgr: nvmem.battery.fccLowCrit:EMERGENCY]: The NVMEM battery full-charge capacity is critically low (30 ). To prevent data loss, the system will shut down in 20 minutes.
Fri Feb 14 13:51:52 GMT [node_name: env_mgr: callhome.battery.failure:EMERGENCY]: Call home for BATTERY (full charge capacity low) CRITICAL.
Fri Feb 14 13:54:53 GMT [node_name: env_mgr: nvmem.battery.fccNormal:notice]: The NVMEM battery full-charge capacity is normal.
- BMC 事件日志:
Feb 14 13:50:44 BMC hsam[1334]: HSAM OS(bmc):cmd(set) FLD(nvbatt-1):fault(Environmental Condition by env_mgr)
Feb 14 13:50:44 BMC hsam[1334]: FRU /chassis-1 LED on
Feb 14 13:50:44 BMC hsam[1334]: FRU /chassis-1/controller-a LED on
Feb 14 13:50:44 BMC hsam[1334]: FRU /chassis-1/controller-a/nvbatt-1 LED on
Feb 14 13:50:52 BMC env_mgr[1470]: Payload EMS: EMS_nvmem_battery_fccLowCrit(30 %, 20)
Feb 14 13:51:22 BMC env_mgr[1470]: Payload EMS: EMS_callhome_battery_failure(BATTERY (full charge capacity low))
