跳转到主内容
磁盘架 DS2246 报告温度过低( UT) 警告警报
86
Visibility:
Votes:
0
Category:
disk-shelves<a>DS2246</a><a>磁盘架</a><a>VPD</a><a>错误482255</a>
Specialty:
HW
Last Updated:
适用场景
  • DS2246
问题描述
  • 磁盘架 DS2246 会报告 UT WARNING 警报、一段时间后、此警告将自动更正。
[FAS-01: statd: monitor.shelf.warning:warning]: Fault reported on disk storage shelf attached to channel 0a. Check fans, power supplies, disks, and temperature sensors.
[FAS-01: monitor.shelf.fault.ok:info]: Fault previously reported on disk storage shelf attached to channel 0a has been corrected.
[FAS-01: monitor: monitor.globalStatus.ok:info]: The system's global status is normal.
Temperature Sensors:
Element Status      Status Bytes  Status Descriptions
 1: NONCRITICAL     03,00,18,01   UT WARNING
  2: OK         01,00,24,00
  3: OK         01,00,2A,00
  4: OK         01,00,3D,00
  5: OK         01,00,28,00
  6: OK         01,00,3D,00
  7: OK         01,00,2B,00
  8: OK         01,00,2A,00
  • 尽管数据中心的温度正常、但每天都会生成警告、并在一段时间后恢复正常状态。
New to NetApp?
