跳转到主内容
磁盘冗余在扩展磁盘架后失败
42
Visibility:
Votes:
0
Category:
fas-systems<a>FAS 8300</a><a>SAS HBA</a><a>2008985501</a>
Specialty:
hw
Last Updated:
适用场景
FAS8300
问题描述
SAS 端口脱机。
11/19/2021 19:26:16 cluster-node01 ERROR sas.link.error: Could not recover link on SAS adapter 0d after 40 seconds. Offlining the adapter.
11/19/2021 19:22:48 cluster-node01 ALERT hm.alert.raised: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 13650257700721330768 raised by monitor node-connect
11/19/2021 19:22:48 cluster-node01 ALERT hm.alert.raised: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 9455720896314018384 raised by monitor node-connect
11/19/2021 19:22:48 cluster-node01 ALERT hm.alert.raised: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 7525643682474166864 raised by monitor node-connect
11/19/2021 19:22:48 cluster-node01 ALERT hm.alert.raised: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 6732447198103538256 raised by monitor node-connect
11/19/2021 19:22:48 cluster-node01 ALERT hm.alert.raised: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 2610812412664285776 raised by monitor node-connect
11/19/2021 19:22:48 cluster-node01 ALERT hm.alert.raised: Alert Id = SinglePathToDiskShelf_Alert , Alerting Resource = 1336282723002157648 raised by monitor node-connect
11/19/2021 19:22:37 cluster-node01 ERROR callhome.dsk.redun.fault: Call home for DISK REDUNDANCY FAILED
11/19/2021 19:22:34 cluster-node01 ERROR sas.link.error: Could not recover link on SAS adapter 0b after 40 seconds. Offlining the adapter.
11/19/2021 19:21:52 cluster-node01 ERROR sas.link.error: Could not recover link on SAS adapter 0d after 40 seconds. Offlining the adapter.
11/19/2021 19:16:33 cluster-node02 ALERT callhome.hm.alert.major: Call home for Health Monitor process schm: DualControllerHa_Alert[50:0a:09:xx:xx:xx:xx:xx].
11/19/2021 19:16:01 cluster-node02 ALERT hm.alert.raised: Alert Id = DualControllerHa_Alert , Alerting Resource = 50:0a:09:xx:xx:xx:xx:xx raised by monitor system-connect
slot 0: SAS Host Adapter 0d (Broadcom SAS3616W rev. 2, SAS,)
Firmware rev: 12.00.00.00
NVDATA rev: 12.03.01.02
Base WWN: x:xxxxx:xxxxxxx:xx
Phy State: [0] Enabled, Rate unknown
[1] Enabled, Rate unknown
[2] Enabled, Rate unknown
[3] Enabled, Rate unknown
Mini-SAS HD Vendor: not available
Mini-SAS HD Part Number: not available
Mini-SAS HD Type: not available
Mini-SAS HD Serial Number: not available
New to NetApp?
