跳转到主内容
币形电池实时时钟(RTC)电池错误地报告低电压或高电压状态
273
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
hw
Last Updated:
适用场景
  • AFF A900
  • AFF A700
  • AFF A220
  • AFF C190
  • FAS9000
  • FAS2750
  • FAS2720
  • FAS2820
问题描述
标识
使用以下方法帮助识别此问题描述。
EMS事件日志
[node1: env_mgr: monitor.rtcLowPower:error]: Real-time clock battery is dangerously low. Replace it at the next available maintenance window.
[NODE1:monitor.chassisPower.degraded:warning]: Chassis power is degraded: RTC Battery is in WARN LOW state current voltage is 2774 mV, normal low is 2800 mV
[env_mgr: monitor.rtcHighPower:error]: Real-time clock battery voltage is above normal (P3.3V Batt is warning high (3307 mV).)
[node1: env_mgr: monitor.rtcWarnLowPower:error]: Real-time clock battery voltage is below normal (2880 mV).
传感器状态
  • 3伏蓄电池传感器将显示为警报状态:
cluster1::> system node environment sensors show -state !normal
Sensor Name              State          Current    Critical     Warning     Warning    Critical
                                        Reading       Low         Low         High       High
Bat 3.0V                critlow        2545 mV     2545 mV     2702 mV     3503 mV     3575 mV
或:
P3V Batt         warnlow     2880 mV    2720 mV    2880 mV    3300 mV    3460 mV
cluster1::> system controller service-event show
Node        ID  Event Location            Event Description
cluster1-01    1   Controller B on Chassis 1       P3V3_BATT: Voltage Sensor 26 UNC
  • BMC命令行界面的 system sensors  和events all  命令或者相应的 SP-latest-IPMI和 SP-latest-syslog AutoSupport部分也将指示问题描述:
BMC> system sensors filter BAT
Sensor Name    | Current   | Unit     | Status    | LCR     | LNC     | UNC     | UCR
P3V_BATT      | 2.840    | Volts    | nc     | 2.720    | 2.880    | 3.300    | 3.460
BMC> events all
Record 904: Wed Mar 18 02:14:02.350000 2020 [IPMI.notice]: 0001 | 02 | EVT: 0157bdbd | P3V3_BATT | Assertion Event, "Upper Non-critical going high" | Reading: 3.307 | Threshold: 3.307
Record 1946: Sun May 29 23:44:14 2022 [IPMI.notice]: 6501 | 02 | EVT: 0150bdbd | Bat_3.0V | Assertion Event, "Lower Non-critical going low"
控制器警示LED
  • 控制器上的琥珀色警告警示LED将亮起
New to NetApp?
