无法通过 SNMP 、 Cshm (集群交换机运行状况监视器)警报访问集群交换机
- 78
- Visibility:
- Public
- Votes:
- 0
- Category:
- fas-systems<a>CSHM</a><a>1089909</a><a>SNMP 社区字符串不正确</a><a>集群交换机通信问题</a><a>检查 SNMP 社区字符串</a>
- Specialty:
- HW
- Last Updated:
适用场景
所有 ONTAP
问题描述
- 在节点重新引导后,将触发以下运行状况警报。
- SNMP 配置已被检查为正确,并且在此警报之前未进行更改。
cluster_name::*> system health alert show
Node: node_name
Resource: switch_name
Severity: Major
Indication Time: Sat Jul 13 09:40:57 2019
Suppress: false
Acknowledge: true
Probable Cause: Cluster switch "switch_name" with IP address
"xx.xx.xx.xx" is not reachable via SNMP. Incorrect
SNMP community string might be configured on the
cluster switch.
Possible Effect: Cluster switch communication problems and
accessibility issues.
Corrective Actions: Check the SNMP community string on the cluster switch
to verify the expected community string is configured.
Use the "system cluster-switch show -snmp-config"
command to view the expected community string.
