由于 HA 不正确, FAS8040 上出现集群互连错误 配置
适用于
- FAS8040
- 集群模式 Data ONTAP 8.x .X
- ONTAP 9.x
问题
虽然集群运行状况良好,但 HA 故障转移不是:
示例:
cluster::*> cf status
Takeover
Node Partner Possible State Description
cluster_01 cluster_02 false Waiting for cluster_02, Takeover
is not possible: Storage failover
interconnect error, NVRAM log not
synchronized, Disk inventory not
exchanged
cluster_02 cluster_01 false Waiting for cluster_01, Takeover
exchanged
注:重新启动任一节点均不起作用,也不会重新启动或重新安装主板。 |
