币形电池实时时钟(RTC)电池错误地报告低电压或高电压状态
适用场景
- AFF A900
- AFF A700
- AFF A220
- AFF C190
- FAS9000
- FAS2750
- FAS2720
- FAS2820
问题描述
标识
使用以下方法帮助识别此问题描述。
EMS事件日志
- EMS事件日志事件 将显示如下内容:
[node1: env_mgr: monitor.rtcLowPower:error]: Real-time clock battery is dangerously low. Replace it at the next available maintenance window.
[NODE1:monitor.chassisPower.degraded:warning]: Chassis power is degraded: RTC Battery is in WARN LOW state current voltage is 2774 mV, normal low is 2800 mV
[env_mgr: monitor.rtcHighPower:error]: Real-time clock battery voltage is above normal (P3.3V Batt is warning high (3307 mV).)
[node1: env_mgr: monitor.rtcWarnLowPower:error]: Real-time clock battery voltage is below normal (2880 mV).
传感器状态
- 3伏蓄电池传感器将显示为警报状态:
cluster1::> system node environment sensors show -state !normal
Sensor Name State Current Critical Warning Warning Critical
Reading Low Low High High
Bat 3.0V critlow 2545 mV 2545 mV 2702 mV 3503 mV 3575 mV
或:
P3V Batt warnlow 2880 mV 2720 mV 2880 mV 3300 mV 3460 mV
- system controller service-event show 命令也会显示故障。
cluster1::> system controller service-event show
Node ID Event Location Event Description
cluster1-01 1 Controller B on Chassis 1 P3V3_BATT: Voltage Sensor 26 UNC
- BMC命令行界面的
system sensors和events all命令或者相应的 SP-latest-IPMI和 SP-latest-syslog AutoSupport部分也将指示问题描述:
BMC> system sensors filter BAT
Sensor Name | Current | Unit | Status | LCR | LNC | UNC | UCR
P3V_BATT | 2.840 | Volts | nc | 2.720 | 2.880 | 3.300 | 3.460
BMC> events all
Record 904: Wed Mar 18 02:14:02.350000 2020 [IPMI.notice]: 0001 | 02 | EVT: 0157bdbd | P3V3_BATT | Assertion Event, "Upper Non-critical going high" | Reading: 3.307 | Threshold: 3.307
或
Record 1946: Sun May 29 23:44:14 2022 [IPMI.notice]: 6501 | 02 | EVT: 0150bdbd | Bat_3.0V | Assertion Event, "Lower Non-critical going low"
控制器警示LED
- 控制器上的琥珀色警告警示LED将亮起
