A400上发生机箱风扇FRU故障
适用场景
A400
问题描述
- EMS报告了以下错误
Dec 06 17:27:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks. Assign unowned disks. One fan has failed: SysFan4 F2.
Dec 06 17:33:00 [node02:monitor.globalStatus.critical:EMERGENCY]: There are no enough spare disks. One fan has failed: SysFan4 F2.
Wed Dec 07 13:31:38 +0900 [node02: notifyd: asup.post.drop:error]: AutoSupport message (HA Group Notification from iscsi-vc054-swn-02 (CHASSIS FAN FRU FAILED: Fan4_2) ERROR) was not posted to NetApp. The system will drop the message.
- 传感器状态为
"BAD"
SysFan4 F1 discrete normal normal GOOD
SysFan4 F2 discrete fault normal BAD
