跳转到主内容
"Active IQ Config Advisor 摘要报告 " 报告 "SAS 布线检查 "
66
Visibility:
Votes:
0
Category:
aff-series
Specialty:
hw
Last Updated:
适用于
AFF-A700
ONTAP 9.7P4
问题
  • "Active IQ Config Advisor Summary Report " 报告 ""SAS Cabling checks
示例:
Description:SAS Cabling Checks
Severity :High Impact
Details :Three paths found from controller node name:******* to the stack on port 0a. Only multipath and quad-path configurations are supported.
  • "sysconfig -a" 日志显示四路径正常。
示例:
slot 0: SAS Host Adapter 0a (Avago Technologies SAS3008 rev. 2, SAS, <UP>)
  Firmware rev:    13.00.00.00
  NVDATA rev:     11.02.17.08
  Base WWN:      5:00a098:00e3028:84
  Phy State:     [0] Enabled, 12.0 Gb/s
           [1] Enabled, 12.0 Gb/s
           [2] Enabled, 12.0 Gb/s
           [3] Enabled, 12.0 Gb/s
New to NetApp?
  • 这篇文章对您有帮助吗?
