跳转到主内容
检测到 " 两个互连链路之一出现故障 " 陷阱警报
36
Visibility:
Votes:
2
Category:
fas-systems
Specialty:
HW
Last Updated:
适用场景
  • FAS8080
  • ONTAP 9
问题描述
  • EMS log 通过互连端口 ib0a ,节点 1 节点和节点 2 之间的端口将立即断开链路并还原。
[?] Sun May 23 13:06:00 JST [node 1: mlx4_intr_handler: ic.linkStatusChange:info]: HA interconnect: Port ib0a link is down.
[?] Sun May 23 13:06:00 JST [node 1: ctrl_hb_port_ib0a: ctrl.rdma.heartBeat:info]: HA interconnect: Missed heartbeat to XXX.XXX.XXX.XXX.
[?] Sun May 23 13:06:01 JST [node 1: monitor: monitor.globalStatus.nonCritical:error]: One of the two interconnect links has failed.
[?] Sun May 23 13:06:06 JST [node 1: mlx4_intr_handler: ic.linkStatusChange:info]: HA interconnect: Port ib0a link is up.
  • sysconfig -a 显示链路状态为活动。
NetApp Release 9.1P16: Wed Nov 14 00:22:10 EST 2018
 System ID: 0537090755 (node 1); partner ID: 0537090720 (node 2)
 System Serial Number: 451713000103 (node 1)
 System Rev: C3
 Interconnect Port 1:
  Port Name:   ib0a
  Default GID:     XXXX:0000:0000:0000:00a0:9800:0035:XXXX
  Base LID:       0x3c
  Active MTU:      4096
  Data Rate:      40 Gb/s (4X) QDR
  Link State:     ACTIVE
  QSFP Vendor:     Molex Inc.
  QSFP Part Number:   112-00374 A0
  QSFP Type:      Active Optical 5m ID:00
  QSFP Serial Number: XXXXXXXXXXXXXX
 Interconnect Port 2:
  Port Name:   ib0b
  Base LID:       0x3d
  Active MTU:      4096
  Link State:     ACTIVE
New to NetApp?
  • 这篇文章对您有帮助吗?
