跳转到主内容
重新利用HA对时发生"未找到本地磁盘"错误
61
Visibility:
Votes:
2
Category:
ontap-9
Specialty:
hw
Last Updated:
适用场景
  • ONTAP 9
  • 存储
  • FAS 系统
  • AFF系统
问题描述
  • 已初始化的两个节点无法启动。
  • 尝试继续 Clean configuration and initialize all disks 选项时出现以下错误。
示例:
 * Press Ctrl-C for Boot Menu. *
 Attempting to use existing varfs on /dev/nvrd1
 No SVM keys found.
 Boot Menu will be available.
 Firewall rules loaded.
 Battery charge capacity: xxxx mA*hr. Power outage protection flash de-staging cycles: xx
 Please choose one of the following:
 (1) Normal Boot.
 (2) Boot without /etc/rc.
 (3) Change password.
 (4) Clean configuration and initialize all disks.
 (5) Maintenance mode boot.
 (6) Update flash from backup config.
 (7) Install new software first.
 (8) Reboot node.
 Selection (1-8)? 4
fm_run0: no local disks found & OFW channel is not up.
WARNING: 0 disks found!
[localhost:cf.fm.noMBDisksOrIc:error]: Could not find the local mailbox disks. Could not determine the firmware state of the partner through the HA interconnect.
WARNING: there do not appear to be any disks attached to the system.
No root volume found.
Rebooting... (press ctrl-c during boot to break reboot loop)
  • 通过  disk show -v 在维护模式下执行comamnd来检查是否已为磁盘分配已颁发节点。
示例:
*> disk show -v
Local System ID: 537093362
  DISK    OWNER     POOL  SERIAL NUMBER  HOME      DR HOME    CHKSUM
0b.00.11   Not Owned   NONE  S396NA0HC11111  Block
0b.00.0   Not Owned   NONE  S396NA0HC11111  Block
0b.00.8   Not Owned   NONE  S396NA0HC11111  Block
0b.00.10   Not Owned   NONE  S396NA0J111111  Block
0b.00.3   Not Owned   NONE  S396NA0HC11111  Block
0b.00.4   Not Owned   NONE  S396NA0HC11111  Block
0b.00.6   Not Owned   NONE  S396NA0J111111  Block
0b.00.1   Not Owned   NONE  S396NA0HC11111  Block
0b.00.7   Not Owned   NONE  S396NA0HC11111  Block
0b.00.9   Not Owned   NONE  S396NA0HC11111  Block
0b.00.2   Not Owned   NONE  S396NA0HC11111  Block
0b.00.5   Not Owned   NONE  S396NA0J111111  Block
New to NetApp?
