跳转到主内容
由于Brocade交换机端的SFP出现故障、C3丢弃并丢失帧
307
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
brocade
Last Updated:
适用场景
  • Brocade Fabric OS
  • ONTAP
  • hyper-v Windows host​​​​
问题描述
示例:
The system failed to flush data to the transaction log. Corruption may occur in VolumeId: xxxxxxxx, DeviceName: \Device\HarddiskVolume123.
({Data Overrun}
A data overrun error occurred - Ntfs
        ​​The IO operation at logical block address 0x1debb18 for Disk 0 (PDO name: \Device\0000002f) was retried
  • 盘C3C3超时 TX丢弃 porterrshow
     frames    enc   crc   crc   too   too   bad   enc  disc   link   loss   loss   frjt   fbsy  c3timeout   pcs   uncor
    tx    rx    in   err   g_eof  shrt   long   eof    out  c3  fail   sync   sig          tx  rx    err   err
 352: 40.0m 183.4m   0    0    0    0    0    0    29.5k   6.3k    10    5    1    0    0   605   0    0    0
  • portstatsshow
portstatsshow 103
er_tx_c3_timeout     360                 Class 3 transmit frames discarded due to timeout
  • Rx 和TX 处于 最佳范围 sfpshow
Port 23:
RX Power:   -1.8   dBm (655.2uW)
TX Power:   -2.1   dBm (618.8 uW)
  • 错误转储可能会记录端口设置
    Switch 0; Wed Jan 29 01:24:01 2025 IST (GMT+5:30) 01:24:01.713417 SCN LR_PORT(0);g=0x4984 D0,P0 D0,P0 186 NA 01:24:01.762542 SCN Port Online; g=0x4984,isolated=0 D0,P0 D0,P1 186 NA 01:24:01.762718 Port Elp engaged D0,P1 D0,P0 186 NA 01:24:01.762731 *Removing all nodes from port D0,P0 D0,P0 186 NA 01:24:01.762918 SCN Port F_PORT D0,P1 D0,P0 186 NA
  • 在中观察到IO帧丢失事件以及C3 Tx超时事件 errdump
CRITICAL, CDVL_X, slot11 port32, F-Port 11/32, Condition=ALL_OTHER_F_PORTS(C3TXTO/min>3), Current Value:[C3TXTO, 20 Timeouts], RuleName=defALL_OTHER_F_PORTSC3TXTO_3, Dashboard Category=Port Health.
CRITICAL, CDVL_X, slot11 port32, F-Port 11/32, Condition=ALL_PORTS(DEV_LATENCY_IMPACT==IO_FRAME_LOSS), Current Value:[DEV_LATENCY_IMPACT, IO_FRAME_LOSS, (20 C3TX Timeouts) ], RuleName=defALL_PORTS_IO_FRAME_LOSS_UNQUAR, Dashboard Category=Fabric Performance Impact.
WARNING, , Flow (SID=0x6cc0c0,DID=0x6c9bc1,Host Port=9/40), Condition=sys_flow_monitor(RD_STATUS_TIME/10SEC>12000), Current Value:[RD_STATUS_TIME, 223776 Microseconds], RuleName=defRD_STATUS_TIME_12000, Dashboard Category=IO Latency.
INFO, FAB1, Frame timeout detected, tx port 1/23 rx port 1/23, sid 123, did 456, timestamp xy
INFO, FAB1,  Local domain 1, port index 123: A zoned device 0x123456 has been quarantined.
WARNING, FAB1, Port 1/23 (Port index 123) has been marked as Slow Drain Device.
New to NetApp?
