跳转到主内容
Exciting new changes are coming to the Knowledge Base site soon!
Starting April 4, 2023, you will notice Support-Specific categorization and improvements to the search filters on the site. In May, we will be launching a new and enhanced Site UI and Navigation. To know more, read our Knowledge Article.
在动态磁盘池(DDP)中、有多少个磁盘可以同时发生故障?
9
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg<a>2009237309</a>
Last Updated:
适用场景
  • E 系列
  • 动态磁盘池 (DDP)
问题解答
  • 在DDP中、两个驱动器可能会同时发生故障、并且不会担心数据丢失。
  • 多个驱动器故障场景、请参见 TR-4652
Scan to view the article on your device
