跳转到主内容
E 系列图形用户界面在主菜单 "Data Could 不从存储阵列加载 "
37
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用场景
  • NetApp E 系列
  • SANtricity 系统管理器
问题描述
  • 两个控制器上的SANtricity系统管理器菜单出现错误
 选择  主页
  1. Failed to retry after 5 attempts final Object null (Web Server 442)
  2. Data could not be loaded from the storage array. One possible cause is the object on which you were performing the operation no longer exists. Other possible causes include network issues, inability to communicate with the controller, or loss of power to the storage array. Check these causes and then retry the operation.
无法从此存储阵列加载数据
  •  在 所有控制器上、SANtricity系统管理器菜单下均未显示任何错误
选择  硬件
无法从此存储阵列加载数据
  • trace.log  在 supportdata 文件中收集的文件中显示错误消息
2021-05-18 08:30:25,617 WARN [Cleaner-1] c.l.a.w.s.WebServer [WebServer.java:2409] [requestId=0, deviceId=N/A] stderr: 2021-05-18 08:30:25.605 UTC SEVERE [/msw_data/bdb] Disk usage is not within je.maxDisk or je.freeDisk limits and write operations are prohibited: maxDiskLimit=10,737,418,240 freeDiskLimit=1,073,741,824 adjustedMaxDiskLimit=9,663,676,416 maxDiskOverage=-9,663,674,195 freeDiskShortage=464,429,056 diskFreeSpace=609,312,768 availableLogSize=-464,429,056 totalLogSize=2,221 activeLogSize=2,221 reservedLogSize=0 protectedLogSize=0 protectedLogSizeMap={}
New to NetApp?
