跳转到主内容
E 系列温度传感器状态未知,并显示警报 "MAX_TemP_Exceeded"
70
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
hw
Last Updated:
适用场景
 E 系列
问题描述
  • 温度传感器状态未知。
Temperature sensor status:  UNKNOWN
  • RECOVERY-GURU-PROCEDURES 将显示 Failure Entry: MAX_TEMP_EXCEEDED-Recovery Failure Type Code: 8
Storage array: NetappE
Component reporting problem: Thermal sensor
Status: UNKNOWN
Component requiring service: Temperature sensor
Tray: Controller/Drive tray 99
  • 由 MEL ()显示MAJOR-EVENT-LOG)受影响 控制器上发生的问题。
A:2020/4/28 下午 04:54:04 (08:54:04) 9658 281c Maximum temperature exceeded - Tray 99 <--CRITICAL
A:2020/4/28 下午 04:54:04 (08:54:04) 9657 281c Maximum temperature exceeded - Tray 99 <--CRITICAL
A:2020/4/28 下午 04:54:04 (08:54:04) 9656 3101 Asynchronous event notification (AEN) posted for recently logged event - Tray 99, Slot A
----> Sense 6/3f/c6 = Unit Attention - Temperature sensor failed
----> FRU group: Subsystem; Tray ID: 99, Type : Temp Sensor, State: Failed
New to NetApp?
