在固件升级期间 E 系列存储阵列上出现数据验证错误
状态信息
适用于
- 控制器平台:所有平台
- 控制器固件:所有版本
- SANtricity 版本:所有版本
问题
在升级前检查期间、 SANtricity 会报告以下一条或多条错误消息:
Data validation error: The storage array cannot be upgraded, as one or more host entries in Controller A did not match with those of Controller B.The storage array cannot be upgraded, as the host port type representation in Controller A did not match with those of Controller B. Contact a technical support representative to resolve this issue.[check spm database] An error occurred while checking the spm database on controller A.[check internal data validity] Data validation error: You cannot upgrade the storage array until the problem is resolved. Contact your technical support representative to resolve this issue.
