跳转到主内容
更换驱动器后,驱动器显示为不兼容
143
Visibility:
Votes:
0
Category:
e-series-systems
Specialty:
esg
Last Updated:
适用场景
NetApp E 系列 E2800
问题描述
  • 更换驱动器后,驱动器显示不兼容,并显示错误 "Firmware error trying to use drive" :
BASIC:
SHELF, DRAWER, BAY STATUS CAPACITY MEDIA TYPE INTERFACE TYPE CURRENT DATA RATE PRODUCT ID FIRMWARE VERSION CAPABILITIES
99, 2, 5 Incompatible 3,726.023 GB Hard Disk Drive SAS 12 Gbps HUS726040ALS214 MS01 DA
DETAILS
Drive at Shelf 99, Drawer 2, Bay 5
Status: Incompatible
Cause: Firmware error trying to use drive
Mode: Incompatible
Raw capacity: 3,726.023 GB
Usable capacity: 3,720.523 GB
  • 初始化驱动器(硬件 > 选择驱动 器 > 初始化)失败,并出现以下错误:
A drive operation cannot be performed because the drive is not in the correct state for the operation. (API 410)
New to NetApp?
  • 这篇文章对您有帮助吗?
