跳转到主内容
已成功创建选定磁盘,但未在 ONTAP 中发现此磁盘
126
Visibility:
Votes:
0
Category:
ontap-select<a>ONTAP Deploy</a><a>磁盘添加</a><a>2008913846</a>
Specialty:
core
Last Updated:
适用场景
  • ONTAP Select
  • ONTAP Select Deploy
  • 磁盘添加
问题描述
  • 从 Deploy 添加存储磁盘失败并显示错误。
Storage add failed for node "node_name" in cluster "cluster_name". If the cluster has been reconfigured outside of ONTAP Select Deploy, run a refresh operation on the cluster, and then try the operation again. Reason: StorageAddDisksNotSeenOnONTAP: Disks were created successfully for node "node_name" in cluster "cluster_name", but were not discovered in ONTAP. If the cluster has been reconfigured outside of ONTAP Select Deploy, run a refresh operation on the cluster, and then try the operation again.
  • 集群刷新未解决问题描述。
New to NetApp?
