跳转到主内容
升级控制器硬件后,无法删除网络端口
450
Visibility:
Votes:
0
Category:
fas-systems
Specialty:
CORE
Last Updated:
适用于
  • AFF 系统
  • FAS 系统
  • ONTAP 9
  • 控制器硬件升级
    • 标题交换
    • 机头升级
问题
在控制器硬件升级期间,我们无法删除现有端口。
::>network port delete -node netapp-n01 -port e0i
Port "e0i" on node "netapp-n01" is hosting VLAN interfaces. Use the "network port vlan delete" command to remove VLAN configuration from the port, then try the command again.
::>network port vlan delete -node netapp-n02 -port e0i -vlan-id 10
Error: Cannot remove port that is a failover target for a LIF. To list LIFs containing a failover target, use the "network interface show -failover-targets
" command.
::>network port broadcast-domain remove-ports -broadcast-domain Default -ports netapp-n02:e0i-10 -ipspace Default
Error: This operation deletes all failover targets from the failover group that is in use by a lif (cluster_mgmt).
New to NetApp?
