跳转到主内容
在ONTAP中、storage故障转移接管命令与halt或reboot命令有何区别?
253
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • AFF型号
  • FAS型号
问题解答
使用 storage故障转移接管 命令(首选方法)时、系统会执行多项检查和验证、以确保接管成功。  如果任何检查或验证失败、则接管将被否决、直到问题描述得到更正并重新尝试接管为止。
在使用 system node halt 或 system node reboot 命令时、HA对中的默认操作是接管暂停或重新启动的节点。  但是、这些命令假定没有任何问题会妨碍正常的无中断接管事件。  此处不会执行通常在存储故障转移接管期间运行的检查和验证。  因此、接管可能无法成功完成、并且系统会发出警告、指出这种情况。
双节点集群的示例输出:
cluster1::> system node reboot -node cluster1-01 -inhibit-takeover false
Warning: Rebooting or halting node "cluster1-01" in an HA-enabled cluster
     may result in client disruption or data access failure. To ensure
     continuity of service, use the "storage failover takeover" command.
     Are you sure you want to reboot node "cluster1-01"?
      {y|n}:
包含2个以上 节点的集群的示例输出:
cluster2::> system node halt -node cluster2-04 -inhibit-takeover false
Warning: This operation will cause node "cluster2-04" to be marked as
     unhealthy. Unhealthy nodes do not participate in quorum voting. If the
     node goes out of service and one more node goes out of service there
     will be a data serving failure for the entire cluster. This will cause
     a client disruption. Use "cluster show" to verify cluster state. If
     possible bring other nodes online to improve the resiliency of this
     cluster.
Do you want to continue? {y|n}:
追加信息
其他信息文本
