在 EMS 中, vscan 服务器显示为“ isconnected ”(已连接)以及“ nblade . nosmbverNegotiated ”(已协商 nblade . nosmbverNegotiated )
状态信息
适用于
- 集群模式 Data ONTAP
- ONTAP 9
- 病毒扫描
问题
- 使用 ONTAP 初始设置病毒扫描解决方案后、 VScan 服务器显示为“已连接”
NETAPP::> vscan connection-status show-all -instance
(vserver vscan connection-status show-all)
Node: NETAPP01
Vserver: SVM1
Server: 10.203.64.62
Server Status: disconnected
Server Type: primary
Vscanner Vendor: -
Vscanner Version: -
Server Disconnect Reason: -
Time When Vscanner Was Disconnected: -
Privileged User Used for Connection: -
Time When Vscanner Was Connected: -
Vserver LIF Used for Connection: -
- EMS 日志显示以下内容:
[NETAPP01: kernel: Nblade.noSmbVerNegotiated:error]: For Vserver "SVM01", Data ONTAP(R) could not negotiate with the client "10.203.64.62" because it does not support any of the SMB protocol versions that the client sent in the list "".
