根卷工作不正常:需要恢复 - AutoSupport 消息
适用于
- ONTAP 9
- 需要恢复根卷,请联系 AutoSupport
事件摘要
此 AutoSupport 消息由 root.vol.recovery.reqd 情况触发,其中报告了以下一个或多个错误消息:
mgmtgwd.rootvol.recovery.newmgmtgwd.rootvol.recovery.differentmgmtgwd.rootvol.recovery.changedmgmtgwd.rootvol.recovery.takeover.changedrdb.env.replicaCorruptrdb.corruption.reportedmgmtgwd.rootvol.recovery.low.space
验证
- 在系统启动期间,将显示以下消息之一:
** SYSTEM MESSAGES **
The root volume is different than the one previously used by this node. This node is not fully operational. Contact support personnel for the root volume recovery procedures.
Or
Internal error: Cannot open corrupt replicated database. Automatic recovery
attempt has failed or is disabled. Check the event logs for details. This node
is not fully operational. Contact support personnel for the root volume recovery procedures. - 意外停电或节点未正确关闭。ONTAP 启动时出现以下消息:
The contents of the root volume may have changed and the local management configuration may be inconsistent and/or the local management databases may be out of sync with the replicated databases. This node is not fully operational.
- 伴随错误消息
"Cluster HA has not been configured"
Warning: Cluster HA has not been configured. Cluster HA must be configured on
a two-node cluster to ensure data access availability in the event of
storage failover. Use the "cluster ha modify -configured true" command to configure cluster HA.
事件日志
event log show -severity * -message-name callhome*
[netapp-cluster-01: mgwd: callhome.root.vol.recovery.reqd:EMERGENCY]: Call home for ROOT VOLUME NOT WORKING PROPERLY: RECOVERY REQUIRED.
追加信息
