跳转到主内容
如何通过命令行续订ONTAP自签名SSL证书
960
Visibility:
Votes:
10
Category:
ontap-9
Specialty:
core
Last Updated:
适用场景
  • ONTAP 9
  • 自签名证书
描述
  • 本文介绍在ONTAP 9存储系统的命令行上续订SSL自签名证书的操作步骤。
  • 如果所需证书过期、FPolicy、Anti-Virus、System Manager或其他与端口443 (HTTPS)的连接可能会失败。
在ONTAP 9.10.1及更高版本中,System Manager还可用于续订即将到期的证书。  请参见 如何在System Manager用户界面中续订ONTAP自签名证书
警告
操作步骤
注意: 如果担心HTTPS服务中断、请在维护时段执行此任务。
  1. 确定 已过期或即将过期的服务器证书:
::> security certificate show -fields vserver,common-name,serial,ca,type,expiration -type server
示例
vserver common-name serial       ca     type   subtype cert-name expiration
clus1   affc190    16E3A53D8D90E881 affc190  server -     affc190   Fri Apr 07 10:59:32 2023
svm1   svm1_A    16FD6CBB01F4F813 svm1_A   server -     svm1_A   Fri Jun 30 14:35:51 2022
2 entries were displayed.
  1. 创建新的自签名证书:
::> security certificate create -common-name <name> -type server -size 2048 -email-addr <email> -expire-days 365 -protocol SSL -hash-function SHA256 -vserver <svm name>
示例
::> security certificate create -common-name svm1_B -type server -size 2048 -email-addr "admin@nowhere.com"
-expire-days 365 -protocol SSL -hash-function SHA256 -vserver svm1
The certificate's generated name for reference: svm1_B
  1. 确定新创建的证书:
示例
svm1   svm1_A    16FD31BFCD1F353C svm1_A   server -     svm1_A   Fri Dec 16 14:35:51 2024
3 entries were displayed.
  1. 启用新证书以供SSL使用:
::> security ssl modify -server-enabled true -vserver <svm name> -ca <auth> -serial <serial>
注意:一个SVM只能启用一个服务器证书。  此命令会将现有证书标记为false。
示例
::> security ssl modify -server-enabled true -vserver svm1 -ca svm1_B -serial 16FD31BFCD1F353C
Warning: The certificate svm1_B is a self-signed certificate, which offers no verification of identity
by client machines.  This presents the risk of man-in-the-middle attacks by malicious third-parties.
Do you want to continue? {y|n}: y
  1. 验证是否已为SSL启用证书:
::> security ssl show -common-name <common name>
示例
::> security ssl show -common-name svm1_B
      Serial             Server  Client
Vserver   Number       Common Name Enabled Enabled
svm1    16FD31BFCD1F353C  svm1_B    true   false
 Certificate Authority: svm1_B
  1. 删除过期证书:
::> security certificate delete -type server -vserver <svm name> -common-name <common name> -ca <auth> -serial <serial>
示例
::> security certificate delete -type server -vserver svm1 -common-name svm1_A -ca svm1_A -serial 16FD6CBB01F4F813
Warning: Deleting a server certificate will also delete the corresponding server-chain certificate, if one exists.
