跳转到主内容
如何测量CPU利用率
918
Visibility:
Votes:
2
Category:
clustered-data-ontap-8
Specialty:
Perf
Last Updated:
适用场景
ONTAP 9
问题解答
  1. 使用sysstat -M 1
::> set diag
Warning: These diagnostic commands are for use by NetApp personnel only.
Do you want to continue? {y|n}: y
::*> node run -node netapp-01 sysstat -M 1
ANY1+ ANY2+ ANY3+ ANY4+ ANY5+ ANY6+ ANY7+ ANY8+ ANY9+ ANY10+ ANY11+ ANY12+ ANY13+ ANY14+ ANY15+ ANY16+  AVG
 100%  100%  100%   99%   98%   96%   94%   91%   86%   81%   76%   70%   64%   57%   48%   37%   81%
CPU0 CPU1 CPU2 CPU3 CPU4 CPU5 CPU6 CPU7 CPU8 CPU9 CPU10 CPU11 CPU12 CPU13 CPU14 CPU15
 78%  76%  77%  83%  82%  83%  82%  82%  82%  82%   83%   84%   83%   82%   83%   82%
Nwk_Excl Nwk_Lg Nwk_Exmpt Protocol Cluster Storage Raid Raid_Ex Target Kahuna WAFL_Ex(Kahu)
    3%    2%    450%     0%    0%    49%   2%   136%    0%    4%   511%( 94%)
WAFL_XClean SM_Exempt Cifs Exempt SSAN_Ex Intr Host  Ops/s   CP
     0%     0%   0%   112%    0%  28%   8%  47111   0%
  • 在上面的示例中、16个核心的平均CPU利用率为81%
最繁忙的域:
  • WAFL豁免率为511-%
  • 网络免除450/%
  • RAID豁免率为136%、豁免率为120%。
  • WAFL的样本间隔98%(Kahu+Kahuna)处于活动状态、4%(Kahuna)用于串行处理、94%(Kahu)用于并行处理
  • 由于WAFL串行处理速度非常低、因此并行WAFL可能会完成更多工作
  • 如果没有其他性能指标、在采样间隔内98%处于活动状态不是一个问题
  • 整体CPU资源变得稀缺、从而增加了CPU工作排队的可能性、从而可能影响客户端延迟
  1. 使用sysstat -x 1.
::> set diag
::*> node run -node cluster1-01 sysstat -x 1
 CPU   NFS   CIFS   HTTP   Total    Net   kB/s   Disk   kB/s   Tape   kB/s   Cache  Cache   CP
                    in   out   read  write   read  write    age   hit  time
  2%    0    0    0    24     7    7    12     0     0    0  >60   100%   0%
  2%    0    0    0     5    11    4     0    24     0    0  >60   100%   0%
  4%    0    0    0     0     9    9    20   1274     0    0  >60   100%   1%
  4%    0    0    0     3     7    8    12    36     0    0  >60    -    0%
  1%    0    0    0     1     4    5     0     0     0    0  >60   100%   0%
  2%    0    0    0    20     6    5     0     0     0    0  >60    -    0%
  5%    0    0    0     8     5    6    12    24     0    0  >60    -    0%
  1%    0    0    0     0    12    13    12     0     0    0  >60    -    0%
  2%    0    0    0     0     3    4     0    36     0    0  >60    -    0%
  • 在以上示例中、可以从第一列(即2%)查看CPU利用率
