AutoSupport 消息:根卷运行不正常: AFF/FAS 系统需要恢复
状态信息
适用于
- ONTAP 9
- 集群模式 Data ONTAP 8
问题
此 AutoSupport 消息由报告以下一root.vol.recovery.reqd
条或多条错误消息的条件触发:
mgmtgwd.rootvol.recovery.new
mgmtgwd.rootvol.recovery.different
mgmtgwd.rootvol.recovery.changed
mgmtgwd.rootvol.recovery.takeover.changed
rdb.env.replicaCorrupt
rdb.corruption.reported
mgmtgwd.rootvol.recovery.low.space
这些错误消息中的每一条还会在登录时显示一条横幅。
示例:
1,
** SYSTEM MESSAGES **
The root volume is different than the one previously used by this node. This node is not fully operational. Contact support personnel for the root volume recovery procedures.
2. 意外断电或节点未正确关闭。ONTAP 启动时会显示以下消息:
The contents of the root volume may have changed and the local management configuration may be inconsistent and/or the local management databases may be out of sync with the replicated databases. This node is not fully operational.
