跳转到主内容
从SANtricity 系统管理器创建镜像或编辑设置时出错
37
Visibility:
Votes:
0
Category:
e-series-santricity-os-controller-software<a>2008507696</a>
Specialty:
esg
Last Updated:
适用场景
  • NetApp E 系列
  • E系列平台:E2800和E5700
  • SANtricity OS 11.50/x 或更早版本
  • Unified Manager 4.2 或更早版本
  • Chrome 80 或更高版本
问题描述
  • 从 Unified Manager 启动 System Manager 。
  • 选择存储 > 同步镜像 > 镜像卷,出现错误,如下所示:
Cannot Access Mirroring Feature
The Asynchronous or Synchronous Mirroring feature cannot be accessed.
To access these features, close your current System Manager browser session and relaunch it from the Unified Manager.
  • 或者,如果存在镜像对,请选择一个镜像对,然后选择更多 > 编辑设置,错误如下所示:
Data could not be loaded from the storage array.  One possible cause is the object on which you you were performing the operation no longer exists.  Other possible causes include network issues, inability to communicate with the controller, or loss of power to the storage array.  Check these causes and then retry the operation.
New to NetApp?
