System Manager登录失败、并显示http错误
适用场景
- ONTAP 9
- OnCommand System Manager (集成)
问题描述
- 无法访问System Manager UI
- 无法登录到OnCommand 系统管理器
- 启用http时、您可以从SPI获取日志
- 由于用户界面上有一个http转发到https、因此无法在System Manager用户界面上执行此操作
- 问题描述 很明显、SSL不起作用
- 在Apache日志中、我们可以找到:
[Wed Dec 02 23:04:36.671053 2020 0000] [ssl:notice] [pid 66541:tid 34376558080] [client 10.10.10.10:36372] [vserver 4294967295] No server certificate chain is configured for this vserver
[Wed Dec 02 23:04:36.671805 2020 0000] [ssl:notice] [pid 66541:tid 34376558080] [client 10.10.10.10:36372] [vserver 4294967295] Certificate-based client authentication is not configured for this vserver
[Wed Dec 02 23:04:36.697214 2020 0000] [ssl:emerg] [pid 66541:tid 34376558080] AH02562: Failed to configure certificate 127.0.0.1:0 (with chain), check /mroot/etc/vserver_4294967295/certificates/ssl/server/20 05B31FE6DD6C66 cluster02/server.crt
[Wed Dec 02 23:04:36.697243 2020 0000] [ssl:emerg] [pid 66541:tid 34376558080] SSL Library Error: error:0E079065:configuration file routines:DEF_LOAD_BIO:missing equal sign (line 17)
[Wed Dec 02 23:04:36.697252 2020 0000] [ssl:error] [pid 66541:tid 34376558080] [client 10.10.10.10:36372] [vserver 4294967295] Failed to initialize SSL context
