使用聚合模型缓存数据创建卷或 LUN 失败,因为 XXXX 的数据已超过 24 小时
适用于
- ONTAP 9
- FAS、AFF 系统
- System Manager
- 创建卷
- 创建 LUN
- CVO
- AppDM(应用感知数据管理)
问题
- System manager 错误:
Aggregate model cached data for XXXX is more than 24 hours old- 命令行错误:
The aggregate model cached data for aggregate "XXXX" is more than 24 hours old. This indicates a problem with the model caching system. Contact technical support for assistance.
mgwd.log:
[kern_mgwd:info:XX]XX:0:ERR: QOS::util: qoshr_get_sorted_aggr_list:src/qos/qos_util.cc:XXXX Failed to retrieve ewma counters for resource_headroom_aggr object instance: XXXX
[kern_mgwd:info:XX]XX:0:ERR: QOS::util: qoshr_get_hr_stats:src/qos/qos_util.cc:XXXXAttempt to get cm object resource_headroom_aggr failed:For resource_headroom_aggr object, no instances were found to match the given query.
[kern_mgwd:info:XX]XX:0: WARNING: APS::aggr_model: src/tables/aps_aggr_model.cc:initHeadroom:XX no headroom available for aggregate XX
