跳转到主内容
根迁移后、Web服务将保持脱机状态、从而无法访问System Manager
267
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
CORE
Last Updated:
适用场景
  • ONTAP 9.3 及更高版本
  • System Manager
问题描述
  • 尝试登录到System Manager时失败
  • 选中Web服务后,它们将显示为脱机
  • 尝试联机失败并返回脱机状态
cluster ::> system services web node show
HTTP    HTTP  HTTPS                  Total        Total
Node          External Enabled Port  Port  Status   HTTP Requests Bytes Served
node01        true     true    80    443   offline              -            -
node02        true     true    80    443   online              64         2852
node03        true     true    80    443   online            3366    213326448
node04        true     true    80    443   online             181        19286
4 entries were displayed.
  • 正在查看  Apache-error
[Fri Sep 11 04:58:17.197701 2020 0000] [ssl:notice] [pid 70701:tid 34376532480] Initializing Data ONTAP SSL. [Fri Sep 11 04:58:17.197723 2020 0000] [ssl:notice] [pid 70701:tid 34376532480] Data ONTAP SSL has been initialized successfully. [Fri Sep 11 04:58:18.311170 2020 0000] [mod_shib:crit] [pid 70701:tid 34376532480] child_init: mod_shib failed to load configuration: Unable to access local file (/mroot/etc/shibboleth/shibboleth2.xml) [Fri Sep 11 05:58:18.988273 2020] [dot:notice] [pid 79728:tid 34376532480] The web services database has been initialized.
  • 查看 SAML 配置
::*> saml status show -inst (security saml-sp status show) Node: node1 Update Status: config-failed Database Epoch: 1 Database Transaction Count: 1840 Error Text: SAML job failed, Reason: Internal error. Failed to receive the SAML IDP Metadata file. SAML Service Provider Enabled: false ID of SAML Config Job: 65
New to NetApp?
