跳转到主内容
ONTAP FC 端口显示低接收功率 (RX) 值
133
Visibility:
Votes:
0
Category:
fabric-interconnect-and-management-switches
Specialty:
san
Last Updated:
适用于
  • ONTAP
  • FCP
  • Brocade SAN 交换机
  • Cisco SAN 交换机
问题描述
  • 根据 fcp adapter show 输出,FC 端口在 ONTAP 上显示低 RX 值:
::> fcp adapter show -instance -node nodename -adapter 0a [...] Received Optical Power: 241.3 (uWatts) Is Received Power In Range: false SFP Transmitted Optical Power: 600.4 (uWatts) Is Xmit Power In Range: true DDM Status: 30 Is Xmit Disabled: false  Is Xmit In Fault: false Is Receiver In LOS: false
  • FCP-Adapter.xml 登录 ONTAP 报告低 Rx 功耗,表明问题在 ONTAP 上游:
  • 以下风险在 AIQM 中报告-
    •  RISK: SFP receive power of the SFP connected to netapp port 9c is below the recommended value.
• SFP 两端都正常。Tx 和 Rx 均在两端的推荐范围内。
  • EMS 日志中,我们观察到 link break detectedlink up 错误以及 AEN 错误:
Wed Apr 12 03:42:08 +0200 [nxx-0x: fct_tpd_work_thread_0: scsitarget.slifct.linkBreak:error]: Link break detected on Fibre Channel target HBA 2c with event status 1 , topology type 1, status1 0x0, status2 0x0.
Wed Apr 12 03:42:09 +0200 [nxx-0x: fct_tpd_work_thread_0: scsitarget.hwpfct.linkUp:notice]: Link up on Fibre Channel target adapter 2c.
fcp.io.status:debug]: STIO Adapter:0e AEN 0x8048 (RECV_ERROR) MboxStatus1 0x1002 MboxStatus2 0xa1
  • 从 Brocade 交换机的 sfpshow 日志:
RX Power:   -1.9   dBm (647.5uW)
TX Power:   -4.6   dBm (349.3 uW)
  • `show interface brief`logs 连接到受影响的 NetApp 端口的 Cisco 交换机端口状态报告为"errDisabled"
Interface  Vsan   Admin  Admin   Status     SFP   Oper  Oper   Port    Logical
          Mode   Trunk             Mode  Speed  Channel   Type
             Mode                (Gbps)
fc1/27    3    auto   off   errDisabled swl   --    --    --     --
  • show int transceiver detail 输出在 Cisco 交换机上报告低 Tx 功率,表明交换机端 sfp 存在问题:
   SFP Diagnostics Information:
                   Alarms          Warnings
                 High     Low      High      Low
  Temperature   40.16 C      75.00 C    -5.00 C    70.00 C     0.00 C
  Voltage     3.33 V       3.63 V    2.97 V    3.46 V     3.13 V
  Current     0.00 mA      12.00 mA    4.00 mA   11.20 mA     4.80 mA
 Tx Power    -40.00 dBm     5.00 dBm  -12.20 dBm   2.00 dBm    -8.20 dBm
  Rx Power    -0.49 dBm      5.00 dBm  -15.20 dBm   2.00 dBm   -11.20 dBm
  Transmit Fault Count = 0
  Note: ++  high-alarm; +  high-warning; --  low-alarm; -  low-warning
  • Cisco 交换机端口的 Rx 和 Tx 值显示为 optimal,端口状态为 up。
fc2/42 is up
Temperature 38.33 C, Voltage 3.38 V, Current 6.54 mA, TxPower -6.08 dBm, RxPower -3.11 dBm
  • 交换机端的端口已切换,但 NetApp 端 FC 端口的 Rx 功率仍然很低。
Tue May 28 23:35:39 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 (SUCCESS)
Tue May 28 23:35:57 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=Interface fc2/42 state updated to down
Tue May 28 23:35:57 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 ; shutdown (SUCCESS)
Tue May 28 23:41:05 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=Interface fc2/42 state updated to up
Tue May 28 23:41:05 2024:type=update:id=10.0.xx.xyz@pts/0:user=admin:cmd=configure terminal ; interface fc2/42 ; no shutdown (SUCCESS)
  • System Manager 中适配器的低吞吐量
  • 作为故障排除的一部分,可以执行以下步骤:
    • ONTAP 上的低 RX 通常表示发射端(交换机/配线面板)的硬件故障
    • 进行电缆测试和配线面板检查,以确认电缆是否正常
    • 将电缆交换到交换机端的另一个可用工作端口,查看问题是否依然存在
    • 清洁电缆和两个 SFP 上的连接
  • VMware 服务器频繁进入 Not responding 状态。
  • 以下是存储端的错误 -
[?] Tue May 20 01:35:58 +0530 [cx-labs-bgl-aff-03: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:1a IO WQE failure, Handle 0x0, Type 8, S_ID: 3002xx, VPI: 3, OX_ID: 4D20, Status 0x3 Ext_Status 0x1d [?] Tue May 20 01:36:13 +0530 [cx-labs-bgl-aff-03: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:1a IO WQE failure, Handle 0x0, Type 8, S_ID: 3002xx, VPI: 3, OX_ID: 4051, Status 0x3 Ext_Status 0x1d
  •  在主机端观察到性能问题。以下是主机端报告的错误:
2025-05-23T06:38:20.431Z cpu85:2098417)ScsiCore: 1823: Power-on Reset occurred on naa.600a098038314a71692454716472xxxx 2025-05-23T06:38:23.249Z cpu24:2098418)ScsiDeviceIO: 4115: Cmd(0x45d9d4a9b6c8) 0x8a, CmdSN 0x800e002e from world 2125982 to dev "naa.600a098038314a71692454716472xxxx" failed H:0x0 D:0x2 P:0x0 Valid sense data: 0x6 0x29 0x0 2025-05-23T06:38:41.558Z cpu30:3060886 opID=f36de402)UserDump: 2823: hostd-worker: Userworld(hostd-worker) coredump complete.
New to NetApp?
