跳转到主内容
由于连接问题、无法访问卷
297
Visibility:
Votes:
0
Category:
fas-systems<a>2009567911</a>
Specialty:
san
Last Updated:
适用场景
  • FC LUN
  • Brocade 交换机上的端口
  • ONTAP 9.x
问题描述
  • 由于连接问题、FC LUN在主机端丢失访问权限。
  • IO WQE 在存储端观察到错误、如下所示、在两个节点上均出现错误。
Tue May 09 09:00:03 -0400 [NetApp-01: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:5b IO WQE failure, Handle 0x1, Type 8, S_ID: 401xx, VPI: 275, OX_ID: 63F, Status 0x3 Ext_Status 0x16
Tue May 09 09:00:33 -0400 [NetApp-01: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:5b IO WQE failure, Handle 0x1, Type 8, S_ID: 401xx, VPI: 275, OX_ID: 4E6, Status 0x3 Ext_Status 0x16
Tue May 09 09:00:52 -0400 [NetApp-02: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:5b IO WQE failure, Handle 0x1, Type 8, S_ID: 401xx, VPI: 275, OX_ID: 58E, Status 0x3 Ext_Status 0x16
Tue May 09 09:08:16 -0400 [NetApp-02: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:5b IO WQE failure, Handle 0x1, Type 8, S_ID: 401xx, VPI: 275, OX_ID: 219, Status 0x3 Ext_Status 0x1d
Tue May 09 09:29:05 -0400 [NetApp-02: fct_tpd_work_thread_0: fcp.io.status:debug]: STIO Adapter:5b IO WQE failure, Handle 0x1, Type 8, S_ID: 401xx, VPI: 275, OX_ID: 71, Status 0x3 Ext_Status 0x2
  • C3 timeout Tx 在存储连接端口上观察到错误、其中报告了wqe错误以及交换机端的ISL端口:
Index Port Address  Media Speed   State     Proto
  8   8   020800   id   N32    Online    FC  F-Port  1 N Port + 1 NPIV public
  9   9   020900   id   N32    Online    FC  F-Port  1 N Port + 1 NPIV public
  46  46   022e00   id   16G    Online    FC  LE E-Port  10:00:88:94:71:9d:xx:xx "SW-XX"
  47  47   022f00   id   N16    Online    FC  LE E-Port  10:00:88:94:71:9d:yy:yy "SW-XX" (downstream)
/fabos/cliexec/porterrshow:
      frames    enc   crc   crc   too   too   bad   enc  disc  link   loss   loss   frjt   fbsy  c3timeout  pcs   uncor
    tx    rx    in   err   g_eof  shrt   long   eof    out  c3  fail   sync   sig          tx   rx   err   err
 8:   1.0g 185.7m   0    1    1    0    0    0    0    48.4k   4    0    4    0    0    0    8.5k   0    3
 9:   4.0g   1.3g   0    5    5    0    0    0    0    64.4k   4    0    4    0    0    0    17.4k   0    5
46:   2.1g 157.7m   0    0    0    0    0    10.5k   0    27.4k 121    1    0    0    0    26.4k   0    20.1k   0
47:   3.7g 348.5m   0    0    0    0    0    0    0    4    0    0    0    0    0    0    0    0    0
  • Frame timeout detected errrdump下报告的错误指示无法将帧发送到ISL端口(此处为Tx端口46)
2023/05/09-11:44:52, [AN-1014], 155073, FID 128, INFO, Switch_name, Frame timeout detected, tx port 46 rx port 8, sid 20801, did 40000, timestamp 2023-05-09 11:44:52
2023/05/09-11:44:53, [AN-1014], 155093, FID 128, INFO, Switch_name, Frame timeout detected, tx port 46 rx port 8, sid 20801, did 40000, timestamp 2023-05-09 11:44:53
New to NetApp?
