跳转到主内容
连接到主机端口的 HP 虚拟连接模块关闭 重复
14
Visibility:
Internal
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
适用于
ONTAP 9
HP 刀片式 VC 模块是主机与 FC 光纤 / 刀片式交换机模块之间的连接。
问题
  • 连接到主机端口的虚拟连接模块报告暂停泛洪,并通过禁用主机连接的端口以及丢失存储路径来做出响应。
虚拟连接日志:
2021-03-07T02:52:57+01:00 VCEFX3C422301R4 vcmd: [ENET PORT:enc0:iobay2:d5:3102:Major]  : Port was disabled because a pause flood was detected.
2021-03-07T02:52:57+01:00 VCEFX3C422301R4 vcmd: [ENET PORT:enc0:iobay2:d5:v1:3102:Major]  : Port was disabled because a pause flood was detected.
2021-03-07T02:52:57+01:00 VCEFX3C422301R4 vcmd: [ENET PORT:enc0:iobay2:d5:v2:3102:Major]  : Port was disabled because a pause flood was detected.
2021-03-07T02:52:57+01:00 VCEFX3C422301R4 vcmd: [ENET PORT:enc0:iobay2:d5:v3:3102:Major]  : Port was disabled because a pause flood was detected.
2021-03-07T02:52:57+01:00 VCEFX3C422301R4 vcmd: [ENET:enc0:iobay2:3020:Minor] Enet Module state DEGRADED : 1 or more ports LOOP_DETECTED or PAUSE_FLOOD_DETECTED, Previous: Enet Module state OK, Cause: Port enc0:iobay2:d5 pause-flood detected and automatically disabled
2021-03-07T02:52:57+01:00 VCEFX3C422301R4 vcmd: [ENC:enc0:2014:Minor] Enclosure state DEGRADED : Some Enet modules & servers not OK, Previous: Enclosure state OK, Cause: Port enc0:iobay2:d5 pause-flood detected and automatically disabled
  • 此外,主机连接的端口在交换机端充当 " 慢速消耗 " 设备
  • 在登录到交换机的某些 NPIV 端口上观察到缓冲区信用超时。
映射交换机端的数据:
Category(Violation Count)|RepeatCount|Rule Name                  |Execution Time   |Object           |Triggered Value(Units)|
Port Health(6)           |5          |ALL_F_PORTS_C3TXT0         |03/04/21 20:26:52|F-Port 11/17     |140 Timeouts          |
                         |           |                           |                 |F-Port 10/16     |156 Timeouts          |
                         |           |                           |                 |F-Port 10/16     |120 Timeouts          |
                         |           |                           |                 |F-Port 3/27      |217 Timeouts          |
                         |           |                           |                 |F-Port 10/16     |139 Timeouts          |
New to NetApp?
This is an internal KB article and its content should not be copy/pasted and shared with people outside of NetApp. Always seek Duty Manager authentication of caller for password reset requests. If you need further assistance post a question in Knowledge Xchange
