跳转到主内容
CONAP-309743:MetroCluster如果在ONTAP 9 15.1.上配置了密钥管理器、则"密钥配置"命令失败
237
Visibility:
Votes:
0
Category:
ontap-9
Specialty:
san
Last Updated:
问题描述
  • metrocluster configure 如果启用了板载或外部密钥管理器、则无法在9.15.1 9.151上运行命令。
  • 如果现有集群配置为使用密钥管理器、则此问题描述将阻止使用运行9.15.1 9.15.1的新节点扩展现有MetroCluster集群。
示例:
cluster_A::*> metrocluster configure
Error: command failed: MetroCluster cannot be configured while keymanager is configured on both partner sites. Disable
keymanager on one of the partner sites and then proceed with MetroCluster configuration. After configuring
MetroCluster, configure key manager on the partner site where it was disabled. If using the Onboard Key
Manager, run the "security key-manager onboard sync" command on the partner site. Otherwise, if using external
key manager, run the "security key-manager external enable" command on the partner site.
New to NetApp?
