如何调查ONTAP CIFS延迟以及Nblade.CifsOperationTimedOut和SpinNp错误410
适用场景
- ONTAP 9
- CIFS
问题描述
知识库文章 介绍了操作步骤如何检查ONTAP CIFS延迟以及Nblade.CifsOperationTimedOut和SpinNp错误410
- 确保环境中是否报告任何性能问题、并且卷(DS ID)在 事件持续时间内具有足够的操作以供进一步查看。
- ONTAP CIFS延迟或减低 、并反复出现
Nblade.CifsOperationTimedOut错误、包括SpinNp错误410:
Nblade.CifsOperationTimedOut: Detected a timed out CIFS operation. SMB command for this operation: SMB2_COM_CREATE, Number of times this command was suspended: 6, Number of times this command was restarted: 0, Last CSM error during this operation: CSM_OK, Remote blade UUID: abcdef123456789abcdef123456789ab, Is QoS enabled: QoS_disabled, Last SpinNp error during this operation: 410, Client IP address: 10.x.x.x, Local IP address: 10.x.x.x, Target Vserver ID: #, Target disk's DSID: 0
- 较新的EMS、记录了错误410的含义
Nblade.CifsOperationTimedOut: Detected a timed out CIFS operation. SMB command for this operation: SMB2_COM_CREATE, Number of times this command was suspended: 6, Number of times this command was restarted: 0, Last CSM error during this operation: CSM_OK, Remote blade UUID: abcdef123456789abcdef123456789ab (node_name), Is QoS enabled: QoS_disabled, Last nBlade error during this operation: 410 (Spinnp op has timed out in WAFL), Client IP address: 10.x.x.x, Local IP address: 10.x.x.x, Target Vserver ID: #, Target disk's DSID: DSID_#, Target Vserver Name: VSERVER_NAME
- 备用表单:
Day MON HH:MM:SS TIMZONE [Node_name]: kernel: Nblade_CifsOperationTimedOut_1:error]: params: {'remoteBladeID': 'abcdef123456789abcdef123456789ab', 'cmdRestartCnt': '0', 'vserverId': '#', 'commandName': 'SMB2_COM_CREATE', 'isQosEnabled': 'QoS_disabled', 'lastSpinNpError': '410', 'localIpAddress': '10.x.x.x', 'lastCsmError': 'CSM_OK', 'clientIpAddress': '10.x.x.x', 'suspensionCnt': '6', 'dsId': '0'}
- SpinNp 410是
SPINNP_ERR_OP_TIMED_OUT、表示 SpinNp 操作在WAFL中超时
