ONTAP 是否跟踪 SMB2 或 SMB3 目录创建延迟?
适用场景
ONTAP 9
问题解答
具体而言并非如此,但目录创建延迟会被整合到 smb2对象的计数器中 create_latency
示例:
Cluster::> set diag Warning: These diagnostic commands are for use by NetApp personnel only. Do you want to continue? {y|n}: y Cluster::*> statistics show-periodic -object smb2 -counter query_directory_latency -instance svm0 -node node1 Cluster: smb2.svm0: 3/10/2022 19:51:25 query directory Complete Number of latency Aggregation Constituents --------- ----------- ------------ 0us n/a n/a 0us n/a n/a 0us n/a n/a 0us n/a n/a Cluster: smb2.svm0: 3/10/2022 19:51:33 query directory Complete Number of latency Aggregation Constituents --------- ----------- ------------ Minimums: 0us - - Averages for 4 samples: 0us - - Maximums: 0us - - Cluster::*> statistics show-periodic -object smb2 -counter create_latency -instance svm0 -node node1 Cluster: smb2.svm0: 3/10/2022 19:54:04 create Complete Number of latency Aggregation Constituents -------- ----------- ------------ 0us n/a n/a 0us n/a n/a Cluster: smb2.svm0: 3/10/2022 19:54:08 create Complete Number of latency Aggregation Constituents -------- ----------- ------------ Minimums: 0us - - Averages for 2 samples: 0us - - Maximums: 0us - -
追加信息
smb2对象包括 SMB3 操作。
